dear all evo 5 owner. i just bought evo 5 and wanted to send for service. i need advise:
1) what other oil that i neeed to change? AYC oil and gear oil must change ! Other clutch & brake oil can check whether necessary to change .
2) what brand of brake pad that usually use? There are a few good brand in the market . One of the best is Project Mule , then Endless . You can use 300degree for street , 500 for street & occasional track , 800~900 for track use . Btw , you must change to steel braided brake hose and bleed it before run .
3) what other part that i need check and service? Timing belt , clutch , all the hoses , radiator got Karat or not , wheel alignment & balancing as basic .
4) what suitable oil for engine? Suggestion is Motul if got budget . Or 99 & etc .
Cheers
Anything you can call Ah Tong at 012-658-2251 or come visit our workshop in Sunway Mas or Dataran Prima KAYU mamak . Location map :
Skyzone Car Performance Sdn Bhd
