Advice to repaint Hood Vent ?
dkny
211
10
518
Is it advice to re-paint the evo hood vent ?
The paint start to fade, and I thinking to DIY it, anyone do it before?
Any paint peeling after sometime(heat) ?
fazidk
3,163
413
5,183
1- remove d vents (if it's removable) or if x just mask tape accordingly
2- wet (soap) sand it using 800-grit then 1500-grit sandpaper
3- spray on plastic primer (if u have) or
4- just spray d required color...thin 1st coat n let dry for 10mins..then proceed wiz 2nd n subsequent coats...3 coats wld be sufficient..
Hope this helps...happy diy-ing
Oh ya another thing I only use samurai brand can spray paint as it's d closest to automotive paint...
ken yeang
6,000 RPM
6,617
1,327
after repainting, try use heatshield under the hood. May save you headache in the future....
victor87
96
19
1,508
I just repainted mine hood vent last month.
It's very easy, few clip to remove and it's out !
I washed and clean the vent and sand and smooothen it out and spray a good 4-5 layers to it and it's looking new again !
We’ve heard the row Porsche had with Nissan and their new GT-R at ‘The Ring’, then there was the incident where Mini called out Porsche to do battle, the point it’s all loud and all to do with marketing ploys and there’s rumour that Bugatti may be getting ready to make an announcement about a certain lap time around a certain and very much infamous ‘Green...
