Adjustable: Kayaba RS Pro
Sapeqlaa
29
1,503
Ipoh
Anybody got this installed?...is it ok?...coz im comtemplating on either GAB soft hard hi lo or Kayaba RS Pro hi lo...significant difference in pricing...GAB @ 2.2k n the Kayaba @ 1.3k++..some of my frens recommended me to go with kayaba as it is not that stiff compare to GAB (note: wife n small baby sometimes ride with me)...
Need advice...thanx..:biggrin:
spring
146
69
Jitra and KL
i agreed that hi/lo/soft/hard is better but if u want to set your absorber to comfort level, why waste your money to buy something more expensive? just my 2 cents opinion..
This simple circuit makes it posible to monitor the charging process to a higher level.
Final adjustsments are simple and the only thing needed is a digital voltmeter for the necessary accuracy.
Connect an input voltage of 12.65 volt between the positive and negative poles and adjust the 10K trimmer potentiometer until Led 10 lights up. Lower the voltage and in sequence all other Led's will light up. Check that Led 1...
