adding more amp to current coil
grstarbuck
8
Hi all i was reading here before, but cannot find the topic anymore...
It was about wiring a 12v 30a relay to the existing coil and supplying direct power from the battery... thats all i can remember..... any sifu out there have any idea of this and maybe a post on the diagram will help...
It said to be able to supply a better spark to the plugs for more complete combustion
Thx:regular_smile:
grstarbuck
8
Thx for the information....i got the general idea now... but need just a little bit more information....
I m using a Bosch 5 points relay and not sure which wire to go which points
30-
85-
86
87-
87a-
this is a 12v 30a one you think it can do the job or do i need to add a fuse on the battery direct to coil connection just in case??
Thx .....:cyclops:
xtorm
1,590
49
grstarbuck
8
More Power
Thx that site was helpfully! It would be best to see and actual working diagram on a car...anyone try this before? Cause was thinking of cheap ways to up the spark of combustion without doing any major changes to the existing wiring....
thx again
:X-:
Northiswara
2,589
7
this thread dies already. maybe the project fail also.
jin,
u got double plug already still interested with this mer??
JINEIL2EN
Over 10,000 RPM!
15,317
525
3,213
Island Of Pearl
team99ers.2.forumer.com
jin,
my engine got 12 spark plug.... not 'double' only...:biggrin:
Northiswara
2,589
7
12????
u are using i-dsl lerr. so should have 8 plug. then another extra 4 come from where? from spare plug? or u put another 4 plug at ur exhaust to make the fire dragger...............
JINEIL2EN
Over 10,000 RPM!
15,317
525
3,213
Island Of Pearl
12????
mine's V6 la....:smokin:
SOHC V6 Twin Spark...:smokin:
hahahaha...:biggrin:
Northiswara
2,589
7
bro,
u want to tipu me kah?
city where got V6?
Hi All, Just installed 4g93 auto, but the problem is my top speed is only 160~170km/h, is it because of my gearbox or speed cut?...FYI i just realise the radiator tank of my new engines actually for 1.5 normal proton engine, i am afraid the half cut which i buy is not come with original parts og 4g93...is there any chance, the engine is using 1.6 or lesser cubic engine gear box?...please help...really need ur advice....or any suggestion for upgrade?
