Absorber modification
-storm-
96
Hi guys.... My car feels very goyang la when going high speed especially when reach 120kmph onwards, it feels like my car like not touching the ground and start to wobble side to side when turning. Is it my absorber too soft? actually very soft la, even my mec said that ! Anyway to mod it making it stiffer? coz i just change my absorber and i don't want to spend more on buying a new set.
I heard from my friend that got ppl will potong the absorber and inject more oil into it to make it stiffer! It that true, im a student and on a tight budget, sifus here pls suggest something to improve my handling! your comments is much appreciated! :_: Keke im Tarc student at setapak! =P
boosook
378
Shah Alam
im not sure the potong potong thingy...but i advice u not to do so beacuse its dangerous...safety first..its better u collect ur money and buy a 2nd hand adjustable or something..will be much safer..
dennisdreams
333
21
We provide original absorber upgrade to heavy-duty (higher damping duty) for RM180/set. so far we have done more than 5000 sets sellling all over north malaysia. if you were interested can pm me. Dun send your absorber to change oil, it's not a proper way to mod a absorber. absorber used fully synthetic oil, if you change hydraulic oil or gear oil will onli shorten it's life spend.
hYred_wYred
297
truck drivers!
bro..
my fren doing some services for adjustable and normal absober,
but only using normal absober (oil type)..
intersted?? pm me..
im from keramat area**
not so far from ur place..
-storm-
96
what u means is change my absorber? but i have already change to a new set! Nwat thansk for all ur suggestion! Really appreciate it! Any more suggestion is more than welcome! :_:
Hmm how about changing to a set of sport springs but use original absorber?
infinity.melvin
SlowPoke
1,600
153
kuala lumpur
Hey guys, any one can recommend good place to mod stock absorber?
Want to try this 'inject oil' method. Preferably area within KL/Subang
How much would it cost?
mysyncorp
9
you can try customs the absorber at Top Perfect (Sg. Buloh). They manufactured HWL but still can help you on this matter.
Just an opinion...
hey guys~~
Right now im driving 1.8T GSR standard spec (without LSD). Any concern if i modified to 4WD ?Will the performance drop after modify it ?or need modify engine for better driving feel??
Due to if i keep high RPM for 1st gear my car will skitting.Feel dissapointed to it.Hence plan to convert it to 4 wd
I have tested frenz wira EVO 4wd standard. The result is good in spint n concering. IS EVO & GSR 4wd are universal. If no, can i install EVO 4wd into my GSR ?
Would...
