about 4G13p to 4G92 SOCH
Target Design
436
Pahang
n
now i plaining change my 4G13p siemens ECU to mitsubishi 4G92 Soch....but that 4G92 Soch is A/T....izzit that 4G92 SOCH engine can plug and play to my 1.3 gear box??one of workshop worker said can use back my 1.3 gearbox..just need change flywheel to bigger size only.....but my 1.3 gearbox is using cable clucth one....and that 4G92 SOCH is using oil Pump clucth one....then izzit still can plug and play???
any sifu here can help???
thanks
Target Design
436
Pahang
n
fstrader said:
wahhh..big roject worrr :tongue:
no lar...sifu..just a normal engine swapping only...hehehe
badguy
951
why wanna change to 4G92 sohc????
get a 4G92 DOHC (non-Mivec) version (but it is very hard to find)
or get a 4G91 DOHC version
the old 4G13p gear box can plug and play with 4G9x series engine
my half cut also auto and i put back my old manual 4G13p gearbox
just need to buy a clutch set including fly wheel (can be from 4G92 or 4G93)
then used back the cable type gearbox !!
but my advice will be
look for a manual halfcut!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
don't used back ur old gearbox because
1. ratio not the same (top speed cannot achieve / have to change gear very fast)
2. heavier clutch feel
3. RPM not so stable (because of the Auto ECU)
Blowfish
137
Sunway/KL
First of all, I'd like to say that it is not totally pointless to change a 92 SOHC engine.
You can just get one from proton ( 4g92p) preferably with the MMC ecu.
if you are a fan of acceleration more than top speed, the 92 SOHC is goona suit your needs just fine. It revs good, and SOHC low end response is better ( there is a thread posted on ZTH, just search ). Pick up can play with 1.8 DOHC 93 no problem. Only cons is that top speed is lower. I tried on my 92p satria, it got to a tad below 200. 195-198 some where there).
And with a grippier clutch and street cams, it is pretty damn fun to play with especially if ur changing from a 12v 1.3
Dear guys,
Anyone knows any accessories shop that can customize EL meter cluster backlight? Am looking for yellow or white backface light. Else anyone knows where to buy the EL element to DIY? Preferably located in PJ area.
Thanks.
