need help for engine mods in a 4g13p proton saga engine
DrB3rt
5
hi all bosses,
i have a 4g13p proton saga engine with 12 valves. All my engine bearings is spoilt. i Would like to change my bearing to racing bearings. I heard that King's bearings are good. Can i use this bearings in my engine. why i am asking to change to racing bearing is because later i want to upgrade to racing cams and pulley. Pls if anyone can help me in the engine bearing cams and modifications and anywhere i can buy this engine parts from.
thanks you
tofu_manic
1,342
91
5,148
if ure aiming to build an all-out high rpm engine, then upgrading the bearings would be worth it
what cams/specs are u planning to use?
lonelylilpig
832
33
As i heard from my friend, guys from matt speed do a great job on regrind your existing cam n give u the type of profile u wanted . Other than put in racing bearings , u can go for crank n conrod balancing. It will gives u more smoothness n can get xtra few hundred rpm.
tofu_manic
1,342
91
5,148
yea matspeed cams give a nice fatter mid to top as compared to the pipercams ive owned previously
biggest bang for buck mod is to swap out the block to a 4g15 one
tofu_manic
1,342
91
5,148
? hehe dont understand wat sweet sweet
lonelylilpig
832
33
4G13 to 4G15 more torque mah, so in another case it is very good lor. Sweet taste means ppl happy, then more power isit more happy ....... lol !!
DrB3rt
5
wah wah all sifu's thanks..
actually i'm also wondering wat specs i can use for my car.
any recommendation wat i can do..
boss change blok too much work i think..he he..some more cost pocket koyak..
he he..
wanted to see if engine can take high revs..n wanting to know wat i can change lo..
cam pulleys, cams..now tat i know, i can take the conrod and crank to balance..
got any number i can call for the matt speed ppl..?
who do i go soo in matt speed thanks ya.. so much..
pls if there's anything else i can do to my engine pls advise..
thanks
lonelylilpig
832
33
Aiyo , i felt guilty to poison ppl pulak...... CNY is close still advise ppl this n that !! Oooops.
---------- Post added at 10:17 AM ---------- 6 hour anti-bump limit - Previous post was at 10:13 AM ----------
btw, u running on EFI or Carb ?
DrB3rt
5
ok thank you so much sifu tofu..
will follow ur advise..he he
any idea where i can get the cams..?
sifu lonely--don worry, every advise is gold to me..
after cny got angpau den can consider 4g15 he he..
thanks ya..
---------- Post added at 10:23 AM ---------- 6 hour anti-bump limit - Previous post was at 10:22 AM ----------
boss im running carburator le..
lonelylilpig
832
33
Like this, its abit hard wo unless u're running EFI ......
I heard some dude with 4G13 can outrun other bigger CC car with a webber . But this option is too risky ....
I suggest u stick with cams, flywheel , PNP, adj cam pulley, fine tuned extractor , or if possible rebuild the engine.
I heard nowdays 4G15 doesn't come cheap. Its quite expensive ....
DrB3rt
5
thanks ya boss..where i can get all the parts ha..?? eg, like type of cams..?? any shop will have ar..
kaki motor ka..he he worries kena kaki potong la..lol..quite ex there i think..
any suggestions..??
lonelylilpig
832
33
I just ask my friend about Matt speed cam, he said ard 1 k plus trade in old cam. But quality satisfaction lar..... The contact i trying to get for u.
DrB3rt
5
ok thanks..so i just put back the original bearings first, den replace the cams ha..
which is d most imp thing to do first..??
or do everything together..u recommend which..?
cams pnp and flywheel, or straight rebuild part by part..?
sorry ar so many quest, still new wor..:]
i'm on behalf my friend having problem with his ferio 95'. in the beginning, his ferio have a chamber problem, so he went to press n burh the chamber.. then after that for a few months, his ferio always have to re-alignment... his tires went out(makan sebelah) from inside... then when he want to turn left, the steering not steer back to normal position like before.
went to workshop, but mechanics also dont know what to do.. ask other, some said chamber problem, some said lower arm...
