4G93T Club
Sep 30, 2010
Never ending problems - Bolt on turbo 4g91 (using gsr block, emanage blue, injector evo3, garret AR48 ) - Can shifus here tell me whether wiring NA can still be used for this modification).
stand3t
58
Imo... yes... most of my friend who is using n.a 2wd gearbox have did it... however... it'll be better for u to consult ur mechanic on that issue first...
weaponzero
51
508
Philippines
Hi 4g93t brothers! my car wont rev past 4k rpm, checked the maf, cam angle sensor and tps. all is ok. is it the ECU? they sey its in "limp" mode. how can i remove it or what other things should i check?
Also, my fuel pump is working when i turn the key "on", (engine not started yet).
Thanks in advance and happy new year!
DLegend
Official Contributor
430
14
5,018
Penang
jayjaynyc.blogspot.com
Check the fuse under the dashboard. There is one fuse with a 'R' sign that might be blown. Mine was in limp mode also, caused by short circuit. After rectify the short circuit, change the fuse and problem solved.
Good luck, bro.
Eswarah149
Jul 15, 2012
11
Johor Bahru
hello any sifu can help me...
my GDi 4G93T speedometer cant work...wire man say change another ecu..so i dont know what to do now...if anyone sell meter 1set also i can buy it...or any other ecu replacement for GDI 4g93t...?:confused:
shiyau
Oct 17, 2011
5
Perak
Wanna ask.. how much bar you guys set on your fuel pressure regulator usually? Mine idle at around 2.6 bar.. and wanna ask if i were to increase it to 3 bar myself would it kacau my emanage's tuning?
Mivec559
210
hmm i think for average is with 3 bar and based on my fpr and my fren's is also at 3 bar..i think u shud set it to 3 in order to avoid insufficient fuel to ur engine..
hi all,
May any expert here advise on wats the differant between satria GTi & satria?
Besides the engine.. chasis/ bodyparts any diffferant?
Thanks.
