4g93 n.a, black smoke
13b
127
had just transplant a 4g93 abt a month ago. the problem is, can't seems to find a solution for the black smoke. sent to some w/shop n most said tht some sensors r spoilt n most probably af sensor, but i don't want to change the wrong parts as they can't guarantee it's the right part. anybody experience this b4? the plug also full of carbon(dry, symptom of rich fuel?) no matter how often u clean em. n one foreman even said maybe a wrongly marked timing belt (while changing). tired of this "maybe". any sifu can hep me out? loc in jb. thanks
badgti
1,264
johor
come over to R-tune garage at austin perdana, behind cheez prata shop.they do a lot of 4g9's there and are well experienced with these engines.
pm me if you need details.
Waja1.6X
209
Johor Bahru
www.facebook.com
13b
127
thanks guys, err.. can give direction or not? map would be a great help, thanks!
liz@rd
492
57
tbh there's no such thing as guarantee unless a part that can be seen with a naked eye , we will nvr know a sensor has KO-ed until u taken it out , i mean some things are meant to be dismantled 1st then only u will know ...
my 2 cents
13b
127
thnks
UnicornSpeed
197
what injector ? 240 ? got two thing on my mind your air flow sensor and o2 sensor....pls run a scanner we be much help.
artworkz
706
119
1,543
JB
o2 sensor no so much effect for rich burn. o2 sensor play small role oni. if car can rev well, there is no timing belt run teeth. ur car is dohc or sohc? u full set 93 convert or mod to dohc or mod block? tell me more.
13b
127
mine is a dohc a/t convert to m/t (eterna body). using 6123 ecu, standard injector (dunno what's the size), evo's fuel pump ( the problem start b4 tht), 454 af sensor(if i remember correctly), n it revs well, very well, the black smoke occurs while idle ( just a bit) n also while revving ( like burning house hahahha)
speed2horizon
2,798
334
1,683
O2 sensor is only used when idle or cruising. When ICU A/F feed back is running on close loop... Else, running on open loop.
Have u tried unplug the battery and plug back after 5-10 mins... reset the ECU.
13b
127
ok, problem solved, change to gti injectors n walla.. problem solved. thanks all
I was moved when my fellow detailing buddy decided to organiszed a detailing session for some vehicles belonging to Yayasan Sunbeams home last Sunday the 17th of January 2010. Invitations were sent out to anyone who wanted to help out for a good cause and also learn more about detailing at the same time, open invitation was sent out to various forum members & car clubs
ProDetailing: FREE!!! Hands on...
