- Joined
- Jun 3, 2004
- Messages
- 197
- Points
- 3,018
From stock block 1.6L lancer mx single mingle cam well done with potato turbo setup and no intercooler.Lower boost and running with VP C16 fuel the machine flow 390whp.
Only one time we boost up to 430whp.Next step we put the one 550cc extra injectors for inject methanol for more boost.
Lancer MX 1.6 SOHC street car bring Girl Friendss.
#1.6 4-Cylinder
# 1.6L Mitsubishi 4G92 Standart bore Block
# [COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]Wiseco [/font][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]Pistons[/font][/color][/font][/color][/color] 81mm CR 9.0:1
# Race Engineering custom Rods
# ACL Race Engine Bearing
# Stock polish [COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]cylinder [/font][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]head[/font][/color][/font][/color][/color]
# Stock inlet and xzos valve
# Custom Billet Single Cam 272deg
# ARP Head Stud
# Cometic head gasket
# RPW Valve Spring Kit
# OEM [COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]intake [/font][COLOR=blue! important][FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]manifold[/font][/color][/font][/color][/color] and throttle body
# 1000cc X4 Injectors
# Bosch 044 Fuel Pump
# Garret PotatoTurbo
# OEM FWD gearbox
# Xtreme Clutch and Aluminium Flywheel
# ECU Microtech LT10s
# Fuel VP C16
# Boost 19psi 390whp(430whp at 24psi)
# Rev limit 7800 rpm
For all buddy SOHC .Don't swap your engine to DOHC.Make it a good HP and nice daily driving.Good respond to overtake and game weekend
we can support for all TECH section for SOHC geng in malaysia.And 1.5L SAGA can blow 300hp with stock block from my setup.
#1.6 4-Cylinder
# ARP Head Stud
# OEM FWD gearbox
# Fuel VP C16
