deacon said:
4 types of Mivec 1.6 engines.
Silver, black, black reverse and mivec MD.
By your dyno sheets and using the CORRECT drive train loss scheme of 15% (Or less) for front wheel drive those Mivec engines still produce under the the factory quoted figure. Drive train loss for a front wheel drive does not exceed 15% otherwise you got stuck with a shitty car like a Nissan Sentra Spec V (USDM Version lost 25% at the wheels - documented by Sport Compact Car magazine).
Aside from that i am unsure of the mods i didn't witness those cars on the dyno and i am still skeptical as to whether they are able to produce that much power. An exhaust mod to 2.3 or 2.5 inches (In diameter) can change the output of the car. Where as the stock exhaust was around 2 inches. (Incidentally i do not consider a car with an exhaust mod stock, even if it was to free 1 cm of space)
Instead of doing a 3rd run on a dyno try a 4th gear run. Its the closest to the crank rotation. 3rd gear measures at the wheels. 4th measures at the crank - this of course is based on my experience spent with my own car and other dyno shoot outs. Or you can always go to MATSPEED for an engine dyno.
You can also check back my findings in one tell tale article on asia temple of vtec. A Cyborg ZR vs an EG6. Despite having less power and more weight the EG6 won in both drag 1/4 mile and race course. The conclusion was that the Cyborg even when it was brand new never had that much power.
Mitsubishi never claimed they had a Mivec 4g92 with 185bhp. Highest claim ever for stock was 170bhp race octane gas.
I guess u still discussing about the 1st gen mivec (which is no longer relevant cause it's old engine) cause on the 2nd Gen mivec there is NO black, silver, MD or whatsoever. FYI, thru my experience owned & mods a Mivec CK with 2nd Gen Mivec and communications with RPW Australia on the Mivec CK performance parts, there 1 only 1 type of Mivec 2nd Gen which rated 185hp. Just info, the Mivec 2nd Gen last time is a popular breed for inhouse racing in Australia.
Dyno sheet normally do proved some indicators on the engine strenght, as we know..but chance of losing more than 20% whp on power is there. For example, my currentAccord Euro R H22A MT 220hp Honda rated, is only around 194whp. That is around only 12% loss (maybe due to 'R' type engine-donno really R or not!). But on the other hand, few of our other normal H22A fellows (MT & AT-black cover H22A, quoted around 190hp by Honda) only get as low as 140whp after dynoed. That is around 27% loss of power. Dynoed done at Speedwork & Links. After mild mods with headers, VAFC, Piping etc most of them can get max of 170whp. So, in real life, chance to get whp less more than 20% is there.
the dynoed sheet i just took from what RPW emailed to me last time, during my tenure with Mivec 2nd Gen. Not really knew the orginality.
U have to clarify which Matspeed.,it's Charlie Matspeed Sek26 S. ALam or vverca. If far i know Charlie, don't think he has the dyno machine. Or maybe dyno shop named MAtpseed in Klang Valley which I donno...have to justify la. For dyno-tune, links & amoil would be better choice.
I've running my 2nd Gen Mivec for few years ago & also now with 2.2DOHC Vtec R on the same time. The bottom-line Nothing much diffrerent for a people like me, i might say.:regular_smile:
