4g91 problems.HELP!
dummy7
40
my car's rpm will drop from normal 900 to 500-600 when driving in the hot weather, especially noon time. and d car performs damn sucks at that time! bt during early in the morning o at nite, d car is ok, i mean d rpm idles stable all d time. anyone driving 4g91 facing d same problem? another thing, i dunno other 4g91 engines, but my engine, when i'm cruising, no matter in highway o street, d rpm will suddenly drop a bit, for like 2 sec, den goes bec to normal. is tat normal 4 a 4g91? pls pls......need help here!!
lighting4G
maybe ur isc /stepper motor at your throttle body rosak edi.... check oso ur fuel regulator...
same thing happened to my 4g91 lasttime.. change both now every thing ok edi.
good luck to you.
Hi there
I am planning to change my throttle body because I have enough of the jerking problems it causes. What do you guys recommend, I mean the brand and the size (70mm, 90mm, oversized?) I saw on mudah.my, there are many options but I'm not sure about this. If it is oversize, is the performance will slightly increase? How about the fuel consumption? Thank you in advance.
