4G13 Sputtering problem ...
Wilson13B
296
30
528
Got a cheap Iswara with 4G13 carby for daily beater & fun , from the day I got it , it has this sputtering problem appears around 4.5K rpms ...
Been replaced the distributor/coil unit & high performance spark plug cable with New ngk spark plug ...
At 1st the problem goes away immediately , the whole performance of the car transform , willingly to rev to 8K rpm at 1st & 2nd gear ...
But after I've driven it hard , when stopped the water temp gauge raise to one bar below red zone & it quickly falls back to normal when I'm on the move again ...
Now the sputtering problem comes back exactly the same point at 4.5K rpm if I floor the pedal , if I kept around half to 80% it will revs smoothly even over 6 grand rpm but if I suddenly floor it , the sputtering cames back ...
It just like a rev limiter , the rev just stays at thr & won't raise ...
What should I need to check ?
Any advice will be really appreciated
The Marketplace Top Posts
guys recently my mom painted the house. during the process lots of paint dust have setteled on the car body and glass. wont seem to go off. i tried polishing the body and glass, using thinner on the glass. any shop can remove this?
