4agze engine using c5X siries gearbox..
nnik
3,676
Lembah Klang
hi to all
Wanna ask about this setup...
as i knew it could be use...
how reliable this setup...
in term of performance how??? pro n cons..
ratio??
appreciate ur knowledge lots...
AE75
278
11
Reliable? - so far no problem... about 150k mileage done...
Pro:
- more smooth on gear 2 to gear 3.
- rev more easy to climb especially gear 3-4-5
- can feel the car more light
- save FC
- drive shaft more easily to source as 4AFE shaft also can be use
- performance clutch and flywheel more easy to source
- starter more easy to source
- reduce weight
Con:
- Loose gear 1 & 2 acceleration pickup like supercharge gearbox can be done
- always have higher rev than c5x gearbox
- can't use 9" clutch system anymore
- starter also need to change
BTW I'm using 4AGZE with C160 and feel much better~
nnik
3,676
Lembah Klang
oic....erm..compare to 5speed...isit OK??? afraid lost the top at 5th gear esp when cruising on h.way...
nnik
3,676
Lembah Klang
anyone here.....ghehehe
3zz
118
45
what i know,wat ppl say from mouth to mouth lah.
c56 compared to e58,c56 can tarik longer.
c52 can tarik more longer.
duno true or not.
cos last time play wif 0-400 with 20v gear 3 they always can tarik longer than 4agze.
normality78
3,052
23
5,138
JB
3zz bro, they can tarik longer coz they can rev higher. C56 ratio shorter then E58, how come it can tarik longer?
---------- Post added at 04:27 PM ---------- 6 hour anti-bump limit - Previous post was at 04:24 PM ----------
AE75 bro,
how long u have that C16 on it? I do toying about this idea
nnik
3,676
Lembah Klang
AE75 bro,
thinking of same Q here...
but i just wana use oni c52 gear box onto 4agze ....
normality78
3,052
23
5,138
JB
But C52, no LSD
nnik
3,676
Lembah Klang
i got 1 lsd gbox...but taken from Levin 92 engine...so i guess its c52....hehehe
pcmoddingmy
1,147
101
www.pcmoddingmy.com
C52 does come with LSD...some champion halfcuts even came with TRD/Kaaz/Cusco LSD :D
normality78
3,052
23
5,138
JB
u mean some do come with or all come with?
nnik
3,676
Lembah Klang
not all bro....maybe its my luck...bought it from enjin lantai non tvis...
normal yes..ae92 dont have LSD for their OEM production..even 4agze from ae92 oso dont have LSD....
n0th1n
1,161
12
japan
junk-dealer.blogspot.com
i think the term that should be used:
factory fitted, after market lsd, helical, mechanical
c58 final drive ratio is 3.9
c52/c56 FD is 4.3
never used c58 tho. sorry cant tell you any pro / cons
nnik
3,676
Lembah Klang
thanks to sifu sarip..
but im looking forward of using c52 LSD to 4agze engine...
vincelee1981
81
6
seremban
hi u all......me had a 4agze on my at151 and i'm using the C5x gearbox but dont know which type gearbox when i bought the clutch plate it is 8 1/2" triniti the sail it was local ae101 manual gearbox and it was fine with until now and dyno yesterday 2nd gear can go until 110 km/h and 3rd gear can go until 150km/h until boost 5th gear is until 210km/h @0.59 bar.....it this normal for ZE? coz i'm new in this,when i bought the car the gearbox was fit in it......
pcmoddingmy
1,147
101
www.pcmoddingmy.com
nnik
3,676
Lembah Klang
tat's really good....how about highway cruising...???
hom much HP produced??????
lets share....
hallo zthorian!
i really need your help on ECU(ems 400/siemens vdo) pin out for wira se, bcos im planning to installed rsm into this car. pls anyone can share me the diagram?
