Road Race Motorsports takes on the Suzuki Kizashi
Dinesh
769
1,700
1,593
The Suzuki Kizashi is quite the looker on its own. A modified Kizashi also recently beat the 200mph barrier at Bonneville.
Still, 185hp in stock form isn’t going to cut it on today’s roads. Road Race Motorsports has taken up the challenge and bestowed the Kizashi with a turbocharger to put power figures in the 300hp range. Furthermore, they’ve also swapped out the stock suspension for a set of sports ones that come in Stage 1,2 and 3 offerings. The brakes were upgraded as well to come with the bump up in power.
There’s a body kit available for your Kizashi to stand out from the crowd. If you find 300 ponies a little too much to handle, there’s also a 200hp kit to start small.
Source: Autoblog
GaBaX
17
3,003
Kuantan
www.friendster.com
the front look like golf gti abit...hehehe
Suzuki Swift also have the almost same grille design as Golf GTi wat...Almost every car had this kind of design....so not just this Kizashi only have this grille design...
It is good that Suzuki had produce their 1st sedan model...
Im driving a wira with converted engine and rear disc brake. It seems that they only assist less than 10% of the braking. The rear disc brake pads are rarely change, the disc looks smooth & there is no cove at the tip of the disc. means it has never really been use. i was hoping to get hand brake stop effect at 80km +, but mech says it not possible. any advice ??
