Perdana Evo 3
Evo 3
  • Perdana Evo3
    Votes: 0 0.0%
  • Perdana Evo3:Need Opinion
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
GABRiEL sYLaR
10
Shah Alam
Hello gangz,
i need info n advise from u'all..
Last month i've just install my Perdana with Evo 3 engine.Currently its does not face any problem at all coz its still with the standard stock for evo 3 (tp dlm enjin sudah taruk sikit2 pye brg)and I've test it from KL to my hometown Kelantan 2 times in this month..currently my engine has done with racing cam,port n polish head,ssqv blowoff,metal gasket,denso iridium plug,r3 cable plug,hks
and samco horse,intercooler evo (standard),hks mushroom air filter,gearbox evo 3 lock 2wd...
Now i'm consider..to do some modification to the engine to increase the sikit lagi performance..
So, i've plan to install the tial 38mm 1 bar wastegate,banana extractor,sard fuel regulator, walbro fuel pump, adjustable campulley hks custom and stanless steel air ram piping (skrg pkai getah lagi..)...
Anyone of you with experience & knowledge..can give me an advice either my current plan is ok or not and also can give me some idea for the budget i need to standby to do the mods as i mention above..how much agaknya..lg murah dapat lg la bagus..tq gangs..:stupid::driver:
kumar22mostwanted
1,562
152
HELL!!!
Hello gangz,
how much boost u running now??
are the internals standard?
sometimes just up the boost u can increase hp already but i think u will need a boost controller to do this and a thicker metal gasket to avoid premature detonation
Veloc
3,234
991
Sabah
I think perdana is best mated to the 6A series... 6A12 Mivec or 6A12TT or 6A13...
Lovely to cruise on the highways and provides plenty of torque and top end power... It suites the perdana character also being a comfortable cruiser ^^
kumar22mostwanted
1,562
152
HELL!!!
but bro gabriel probably targetting 300whp onwards thats why cannot use 6a12tt :rolleyes:
GABRiEL sYLaR
10
Shah Alam
currently my boost cut at 1 bar lbh skit (1.3)...my plan now is to increase a little bit more performance especially to increase the 'pick-up' without burden the engine..of coz la the problem is the budget but can u suggest a reasonanable price to do some modification like installing the banana extractor (second hand pun takpe),stainless steel air ram...etc
kumar22mostwanted
1,562
152
HELL!!!
how much budget???
umm as far as i know banana provides for a smoother flow of gases but im not to sure how this affects the pick up/top end:hmmmm:
TurboRai
28
sound like weird lah bro syler..normally,we install fuel regulator,fuel pump walbro,AFC and metal gasket first..then u install lah others toyol like u said..hi-cam,adjes-pully,banana,wasgas and wut so eva to avoid tak ckup fuel in ur engine..quite dangerous bro..once ur piston tembak n conrod jammed,,no more story..find new engine hehehe..but no wonder lah u got big money..my advice if u want up boost,u hv to find AFC,boost cntroller,Blitz air cleaner,banana(or just mod manifold yg ada tu pn xpe utk msuk wasgas n d.pipe) 38mm wasgas (< 1.5bar boost) s.steel air ram piping and exhaust temp. sensor...yg lain2 otai's tebo can top up which is x ckup perisa..hepi mod..cheer's :D
kumar22mostwanted
1,562
152
HELL!!!
who say 6a12tt cannot approach 300whp? even std can tapau evo on highway.....
if i masuk AR70 turbine single turbo.. can get 300++ whp bro.
heheh betul betul top end very very nice and smooth
wahh i rarely hear of eterna 300whp maybe thats why i assumed it cant be done :rolleyes: my bad bro should have done some research first
most of the time i hear 300whp+ i assume evo lol
kanan
908
52
yup wish to see the 300whp tt too for a role model. i'm lack of 50
DanzEterna
15,911
3,371
www.primeperdanaclub.com
kanan, all u need is some 800cc injectors & kacuk your gbox, by then
u will be able to reach 300whp.
kumar, no hal......anythings possible ma......AR70 single turbine conversion would be my dream....rather than spend money to convert to evo. costs - close to rm10k.
kumar22mostwanted
1,562
152
HELL!!!
yeah bro you shouldnt convert to evo coz u already got eterna
like me was running standard 4g93 auto somemore so i needed the extra OOOMMPHHH!!! badly hehehehe
actually i feel eterna is nicer for perdana evo is nicer for the smaller wira/satria/putra
wahh why wannna change to so giant turbo sure got big lag rite plus i heard twin turbo more responsive than single
kanan
908
52
still collecting the internals for future works. not easy to find lah
What is TiTAN custom build performance shock absorber?
TiTAN's are proudly 100% Malaysian designed and built custom build performance shock absorber. Designed as the ultimate custom build shock absorber set for Malaysian roads and drivers! TiTAN's been around for 5 years.
TiTAN is an inverted monotube design, ala WRC/Rally cars style for maximum strength AND durablity for Malaysian roads.
What is a monotube?
a monotube is a single tube where all the damper oil...
