Operating Temperature of Perdana V6
Rex551
133
22
Dear Sifous and Wheel Guru's..
I am going to service my Perdana V6 2.0 (A) Radiator. Anybody whose got an idea of how high the operating temperature in the radiator is, do update here.
Also,
What's the most suitable coolant for Perdana Radiators. This is because I've noticed that the heat these engines generate are quite high.
Others with Radiator servicing experiences are also most welcomed to join in on this thread.
So start typing for my sake...
:thefinger:
Thanks
Rex551
133
22
Haiyaaa...
No one wanna give suggestions ahh ?...
Atleast recommend a great coolant lar....
---------- Post added at 02:40 PM ---------- 6 hour anti-bump limit - Previous post was at 02:11 PM ----------
Any feedback on the "Dei Radiator Relief" ?...
Thermal Chemicals | Design Engineering, Inc.
---------- Post added at 02:40 PM ---------- 6 hour anti-bump limit - Previous post was at 02:40 PM ----------
DanzEterna
15,910
3,371
www.primeperdanaclub.com
ok la bro...i will type for u hehe....
operating temperature - should be not more than half. if more than half, youre in big trouble....before this i was using ori 6a12tt radiator, the temp always shows half, no matter rain or no rain, night or day. now im using RVR radiator, its slightly bigger, at night or cold days, the temp will fall to 1/4.
i suggest u use nissan radiator fluid, last time i used toyota, not very good.
1 btl rm45-50 use 50/50
Rex551
133
22
Thanks Danz,
I'll take note of the Nissan coolant. But what about the "Radiator Relief" ?.
Nobody used it before ahh ?...
Rex551
133
22
Wua Lau eh....
Does that mean once poured into radiator no need to top up with water later on is it ?....
Hmhh
sounds like the criteria for racing engines wuo...
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
team99ers.2.forumer.com
Wua Lau eh....
Hmhh
not only for racing, got for street use 1... can tahan 3yrs no need to change 1...
try Billion la.. sure good..
DanzEterna
15,910
3,371
i was using 100% coolant before...but some ppl say its not good...
but so far ok only...im using green color...cos cheap ma.
wat is a radiator relief?
i would try water wetter though....
edwin_lcw
1,242
Setapak
hey danz the RVR radiator suitable for NA anot ? i also wan change leh ....
the RVR radiator is 3 rows ? PnP ?
jpoplover
7,726
1,410
Nilai
redline water wetter user here. so far so good.....
recommend for TS
Rex551
133
22
Guys,
Thanks for the feedback. Will post updates when I'm sending my car for the service. I think I'll stick to a good coolant due to my budget. Hehahehe
Danz,
The "Radiator Relief" seems to be some kind of substance you add into your radiator along with your coolant and water. I myself came to know about it here only. That's why I had asked feedback from those whom have used it. It's from Dei.
The link is the earlier posts above....(Thermal Chemicals | Design Engineering, Inc)
DanzEterna
15,910
3,371
RVR radiator could fit pv6 na, but u need to fabricate a bracket to fit the fans..
even v6tt fans are slightly smaller to fit RVR radiator...
---------- Post added at 09:55 AM ---------- 6 hour anti-bump limit - Previous post was at 09:49 AM ----------
A Post Every 5 Mins
how to keep the white car white?
Malaysia is known for its tropical climate - plenty of heat & plenty of rain & plenty of acid rain = TA DA -------most severe acid rain
in the world
how to keep the white car white it is too much a challenge to keep our ride clean & looking cool....not easy & quite hard to achieve it...ended up....we let other help us to do it.... for we know the best that we can ever do for our car is to take ownership of it...
