need help from all master
as topic,
persona B line (M)
start engine RPM run to 8k can drive but agar 3k rpm then cut off.
use OD check error code water temperature sensor voltage low.
i change the sensor, few hours after same thing, then i change the harnes (only engine bay area) and problem same.
anyone have problem like this before?
original ecu can repair or need change?
thanks for read n reply
as topic,
persona B line (M)
