My ceFIRO
seizai
937
gear oil & clutch oil is in different place?
---------- Post added at 12:56 AM ---------- 6 hour anti-bump limit - Previous post was at 12:34 AM ----------
I bring my A33 to TKA in nibong tebal last saturday. The person in charge Dennis told me that the "bump stop" on top of the absorber wear already. And the absorber no problem. Just replace the "bump stop". This wear causes a clog clog noise when go over bumps. All nissan has the same problem woh... So he ask me to go get the parts for him to replace.
I search bump stop from unker google and it turns out another thing. So I am not sure if i were to mail order from PH auto, they will send me the correct items.
After searching for the parts assembly, found that there are so many parts sandwich in between. And NONE of them name BUMP STOP.
"mounting insulator and rubber parts"?
i doubt any shop selling that part only unless it is local made adjustable type
weikee
924
15
Are you referring to hydraulic clutch? that one only if you are driving manual mah. is same as brake oil...is difference oil with g.oil.
And BTW, use the Nissan D-Matic, is still the best for Nissan box.
seizai
937
confuse with that 2 oil... never change clutch oil b4 :banghead:
my previous MT car only use 1 oil :banghead:
weikee
924
15
engine oil where got burn smell. Look to me is common fatty oil leak problem. from engine oil seal and flywheel oil seal.
If you going to take the things down for oil seal repair, must well change the g.box oil seal too.. everything is already down. the oil seal won't cost much, only the labor that are costly.
sb3
1,141
14
5,138
how to check gear oil level?
Seizai, you need to go underneath your car , take out the rubber insert at the gear box and dip your finger inside the hole. if your finger is filled with gear oil , then no need to top up loh. BTW, dont use Nissan matic g/box oil as you are using manual transmission and oh, your g/box oil will not have burning smell even how hard you trash it. Only AT have burning smell. (Unless you have changed to AT)
seizai
937
A32 got manual trans model meh?
---------- Post added at 01:41 AM ---------- 6 hour anti-bump limit - Previous post was at 01:32 AM ----------
wow... need to climd in again
XTEC
873
219
jus snap some pic
Oil stain feel bit greasy, no burn smell like engine oil. Wonder what oil is that...
bro check ur power sterling oil , any leak? If not maybe from joint flywheel area to gearbOx.
sb3
1,141
14
5,138
Aiyah, our fatty tends to leak oil all over the engine due to ageing leh. just make sure you check all the oils regularly and wash off the oil with engine de-greaser. Will save you money and time. Don't worry, the engine will not breakdown due to oil leak.:thefinger:
seizai
937
i oledi wash part of stain...
u know la felo much lower than usual car need jack up only can climb in...
some neighbour very ke bo one... look here see there like i curi car
I dream a dream..............Susan Boyle sung through her hearts and not her look and got the whole world attention
My client called me to book for a detailing date, He desire an ultimate protection on his new Mclaren
This is one of the 10th unit brought in, it also have been sitting in a warehouse for quite some time!
I foresee work and lots of works to be carried...
