Wastegate Explained.
veilsideboyz
1,616
17
Wah.... after CNY use CNY Angpao to mod kah..? Lolz... The reputated exhaust shop will be able to do it fo u...
Point down becasue there is no where else to point. Takkan wanna point on the firewall ma...
Ya...Waiting for ang pao to mod... Economic really drop..... :rolleyes:
Ok ! Thanks !! :biggrin: I scare after pasang wastepipe dont have the fear sound.....
Because some of my fren install wastegate wastepipe/screamer pipe.... their wastepipe no sound.....:dancing:
speed2horizon
2,798
334
1,683
U install adi, the ketuk the end, make it leper abit. Sure sound garang... Don't worry.
veilsideboyz
1,616
17
Sunway bakar maybe... coz can direct go tune :biggrin:
btw..thanks taiko! I will tell that guy make the wastepipe LOUD!:biggrin:
Bro ~ Why this wastepipe ..he didnt point the floor and he connect to the exhaust there..
Any idea?
speed2horizon
2,798
334
1,683
Any idea?
This engine owner is my kind of ppl. 3 reasons.
1) for the peace of ears. No wastegate sound. I personally found the NOISE irritating.
2) better fuel consumption.
3) silent killer.
My car doesn't even have blow off sound. Hehe....
veilsideboyz
1,616
17
wow...this guy is my fren at out station...he is using GT35... silent killer...sound cool!!
Btw... I love wastepipe + BOV sound :D Hehe..~~~
Now a lot of sillent killer at the street..
speed2horizon
2,798
334
1,683
Diam diam powerful shiok ma. Once a while bising abit ok la. Bising bising kena potong quiet car malu ma... Hehe...
veilsideboyz
1,616
17
Yaya! Agree ! :D
Actually bising just to show off when you are at infront of many people :)...they will think your car is fast....sillent killer ofcourse is good...but when you are at those many ppl place...they wont know how fast is your car... my opinion la ~ Hehe... :biggrin:
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
Any idea?
for me leh,this kind of setup is ok for street use.it obstruct the exhaust gas flow on boost.
the higher the boost,the exhaust flow become restrictive and causes turbulence in the
exhaust pipe.just my 2 cent.
speed2horizon
2,798
334
1,683
Yes brudder, we're talking abt street car now. My set up allows me to be loud or quiet. But I still like it to be quiet.
Btw, for street purpose ... We normally vent out the exhaust completely. Track purpose what's the use of the muffler..? It's also a restriction to ur exhaust...
And if u try it on a dyno, the difference is not too obvious. A few horses maybe...
pampersdry
62
pahang
bro kenny....how much do i need to spend my money to make the wastegate piping? pm me.... running low of $$$$$ :banghead::banghead:
i still wanna put the wastegate...even it coz me eat sardin everyday.... :rofl::rofl:.....
speed2horizon
2,798
334
1,683
Lolz.... so damn desperate meh..? Okay... There are other options...
As u've mentioned, u're using an RVR engine. So, I assume u're using a TD04L. Well, even if U're using a TD05. It doesn't matter.
If ur investment are purely for the NOISE... Opss... I mean sound... Then U can just call JIAN HANG to direct the waste pipe out from the exhaust instead of venting in...
However, if u really know how much the an external wastegate worth installing, what u can do is.. throw the original waste dish.. Port it to 38mm. Then, at o2 housing, direct the hole to the external wastegate. And from the wastegate, point it down to the floor.
That's the actual way of installing an external wastegate onto a MHI turbo on a stock manifold.
Or else, to look gaya, just plunk in banana.
pampersdry
62
pahang
zzzzzzzz....prefer the NOISE + Performance....hence my boost only 0.5.... that why i wanna throw some money to put the wategate..... got around 1.2k only.... :driver:
speed2horizon
2,798
334
1,683
Tial wastegate = 800-850
To remove the flap + port the turbine housing = 180-250
New exhaust O2 housing + piping modification =300-400
that's the rough costing of the $$$ u gonna spend.
Or u go for the cheap way. Cut the hole on ur manifold. Weld a pipe on the manifold to the wastegate, then close the flap on the turbine housing and weld the actuation lever. And there u go.
But if the tahi welding drop into ur exhaust manifold, there goes ur turbine fins. Unless the installer very detail n knock out all the shit completely. Then, it's ok.
veilsideboyz
1,616
17
Taiko , I also boost 0.5 ... And I just bought Tial wastegate 0.5 spring....
actually external wastegate wont help to gain hp ...:rolleyes: just love the sound yeah !!
wow... taiko...I think will charge me alot for install external wastegate ..need to port @#$%^ and need to replace turbo.... I think will above RM2000 ??? :(
speed2horizon
2,798
334
1,683
That's for MHI turbo lag dude. U already using T25. The turbo inlet flange same as t28 wad what's the problem?? If u are already using a stainless steel exhaust manifold, just add on an external 1 1/2 inch schedule 10 stainless steel pipi at the place where the 4 runners joins together. And weld the internal wastegate lever of ur turbo. Apa Susah???
veilsideboyz
1,616
17
Not susah ~~~ Everything is ok,,,,, Just the "Money" problem ! :biggrin:
Hope wont charge me a lot......
ya..the flange is same... but the oil line have to change....the maybe the air filter to turbo piping have to change to 2.5".... now is 2" nia....too small......
speed2horizon
2,798
334
1,683
This t28 turbo is water n oil cooled. So water line very important if u r going to use ur car to travel long distance. If turbo overheated, byebye...
Power is relative, at least for petrol heads, and warp speed just doesn’t cut it for some. The Canadian owner of this Chevy Camaro probably wouldn’t fall into that category either, he needs one just for himself and all the raging 1,400 horses he has under the hood of his car...
