GODSPEED PROJECT : 44MM V BAND RS-SERIES WASTEGATE (universal)
Made in USA.
- comes with 5 psi , 10 psi waste gate spring ( combine both springs for 15 psi )
- dual port. accurate boost
- ultra durable diagram (diaphram)
- comes with all the hardware (bolts, gasket etc)
- accurate boost pressure
- high quality appearance
- simple one step process for removing or installing different wastegate springs
- 1 year warranty ( if installed by professional)
this wastegate is 4.10" inches tall.
5 psi spring : outer diameter 29mm / length : 36mm
10 psi spring : outer diameter 44mm / length : 68mm
example : you can use 5 psi spring by itself or the 10 psi spring by itself or even combine them up together for 15psi.
Made in USA.
