how to built 2.2 stroker kit???
ronniehor
903
any one no how to built 2.2 stroker kit;
piston size???
conrod size???
crank size???
etc:
thanks
ronniehor
903
hihi...maybe some day lal....i am beginner so need some advice,i here some story got some con shop using OEM piston and cut the piston head and do the con job ezzit true???,and the con shop change to the owner mahle forge piston price ezzit true???
huakenny
LB Performance
9,126
240
Kota Kinabalu
tats just lower the compression rite....size the piston size remain, cc remain..rite?
blue.taxi
427
12
I dont think is to lower the compression, but is coz the piston is tooo high & it will hit the engine head or damage the top part.... Also the top part of the piston is the most presure part in the engine w/ all the heat. I dont think I wanna cut the piston head leh.... hehe
ronnie,
Not con shop lah.... I will said is cost saving mah.
huakenny
LB Performance
9,126
240
Kota Kinabalu
ronnie,
most car cut the piston head, especially those cant find replacement piston. i.e for BOT purpose or boost higher application
Sep 26, 2009
Ronnie,
You mean got customer found out about this?? Hopefully the truth will be revealed and justice can be done. :mad:
fc3snyc
17
12
1,503
NYC
Wiseco sells a stroker piston, 131.50 rod length with a -17.8 Dome Dish.
Pair that with the 2.5 Liter STI Crankshaft. The only thing is the shorter connecting rods. I think PE sell one.
limfk7
211
19
PENANG % KEDAH
The rod in ej25 and ej20 is exactly the same
hey guys,
i have a problem with my car.. the steering vibrates excessively from about 90km/h onwards.. i have changed new tires.. rims checked not bent, alignment and balancing done.. what else could be the cause of this? btw after doing alignment and camber alignment the vibration got stronger.. my car set up is 4agze custom made driveshaft on the left side to correct length but same spec as ori gze shaft.. right side is original gze drive shaft. bearings are relatively new.. hope someone...
