4g92 SOHC To Dohc
mr_lageenda
65
Hi everybody...:biggrin:
i hope everyone can help me
do some modification
at my car
i use wira sedan 4g92
before this i have convert the head
SOHC to DOHC.
now i use original blok 4g92
use 4g93 from putra (already port polish)
throttle body perdana sei
intake manifold 4g93
injector 4g91
distributor 4g92 but have been skim
original wiring n ECU 5806
4g91 cable plug
3 plate clucth exedy
4g91 gearbox clucth pump
4-2-1 extractor 1.8"
straight ekjoz
Open Port
now i what i need is
...PICKUP....
what can i do to get more pickup
i think my car now not so good..
pickup very2 bad..
please everyone help me...:confused:
ART///SPEED
287
i give you a hint lighten some part and change gear box or swap with friend...
Dampachi
34
1,508
4g91 Gearbox
Clucth Pump
1st of all yur 4G91 gearbox got low final drive ratio...thats why u have no pick-up
u should change to more higher FD ratio, at least 4G93/92 gearbox
or if u have enough budget, try to get 4G92 mivec gearbox
mr_lageenda
65
ooooo....
somebody said to me..
now i use 4g92
but use 4g91 gearbox...
that one said,i have a good pickup
bcoz big ratio
but lost top speed..
that true..??
so i must change gearbox 1st
if i need more pickup....
mr_lageenda
65
Extractor Zenden 4-2-1
Header 1.8"
After Nenas 1.6"
Standart bullet
Piping i not sure..
2" or 1.75"
Bcoz why,i go to 1 shop n tell i want piping
they ask me what CC engine use
i said 1.8 (Previous Engine)
pomen said u should use 2"
but 2" outside or inside
i dont know
forgot to asking
i will cek that piping size
and then i will let u know
mr_lageenda
65
Extractor size is 1.8" until nenas
After nenas 2" smpai blakang
Straight paip
Now my pickup is ok..not bad ..
rpm 1-3 ok
rpm 3-4 lembab skit
rpm 4-6 ok la....(tp msh kureng)
why happen like that...
anyone can explain to me...
what or any modification should i do..:rolleyes:
My planning is
1-Use metal gasket
2-Plug Iridium Power
3-ECU Remap
4-Change gearbox
5-Any part should i do..??
thnks evryone to try help me...
think to change it into GTR spoiler xD.....izzit posible?
and i m new to here
which area should i post this question
[in KL/Sel where got shop is customize produce spoiler ?]
