Need some help here
Killerz
229
www.teamswap.co.nr
Hi guys,im driving a 1.5 wira manual. After i convert my car to manual,my car have some problem.
Whenever i shift to 2nd gear a fast speed,i can hear a loud krrraak sound and the sound is like i shift gear without pressing the clutch. This also happen if i revved on 1st gear. What are the problems and how to solve it? Really frustrated
cartoon
953
11
KevinGarage.com
www.kevingarage.com
Check your clutch cable, there must be some free play when you depress the clutch.
Do not adjust the clutch pedal position until there is no any free play left, although the clutch can grip very fast, it also mean the gap between clutch and flywheel are too near, when both metal head up, they will expend and touch each other, and you can't de-clutch any more.
This is very dangerous, I have seen a lot of young people doing this, racing mah.....:hmmmm:
Killerz
229
www.teamswap.co.nr
My clutch is hydraulic type woh. I think not clutch problem since i don't have any problem with other gear,just 2nd gear.
cartoon
953
11
KevinGarage.com
www.kevingarage.com
Oh-O.... that sound really bad, I "guess" may be the gear has broken...
Damage first and second gear is very common in local malaysia, better send your car to proton service center for check up, so no need to think too much ^_^
Don't worry, be happy ^_^
cartoon
953
11
KevinGarage.com
www.kevingarage.com
Hmmmm... not sure bro, but better send it for check up.
Of course, service center should be better, because you do not know some Ah beng really did the job or not...:hmmmm:
Bump: For service center, they will give you a quotation list before start to repair.
Base on the quotation list, you can decide want to repair or not ^_^
wira3319
258
7
Bro, maybe something in your gb has broken, last time i'm also face that...got change to gsr gb one..
jinkl
4,624
376
3,183
the krak sound is the wear of synchro inside the gearbox, u have to open up the gearbox n change the synchro, if cant source out for synchro in sparepart shops , errrr either drive like that or change gearbox kekekeke
normal , synchro will wear if u shift gear harshly
Killerz
229
www.teamswap.co.nr
wa change gearbox ah,no money lo.
last time auto gb kong d convert to manual already spend alot money
any idea around how much to change the syncros? i just need to change 2nd gear syncros right?
JackWaiKit
262
5
www.friendster.com
ya...
better make it asap...
or else when the gear residue getting more, u will also spoil the others sync gear...in fact the gear will also affected...
I also the same prob...
Just change gear oil frequently!!!
Coz no have $$...just leave it 1st...
JackWaiKit
262
5
www.friendster.com
If there is no any incident on ur clutch & others sync gear, just ard 400 gua!!!
I guess...
The labour is expensive!!!
Ur f'man need to dismentle he GB layer by layer!!!
Good luck!!!:wavey:
hello,
im using Saga Blm 1.3 and i am interested to convert it to 1.6.
i heard about changing stroker kit and several other parts to 1.6.
but i need a lil more specific info. is there any garage do this service or any other cheaper way like chop shop for parts etc etc..
thank you!
