Light weight crank pulley good or bad
cnxnet
429
want to know more about light weight crank pulley
some say good, some say no good for top speed
some say can gain hp but some say is rubbish.
any one can share?:confused:
zac
1,347
231
Johor Bahru
I used it b4, install lightened crank pulley in my E34 520 BMW, also coupled with elec fan... the old bmw shifu was murmuring at first that i was wasting my money so on so forth, but after we tested the car together he was impressed with the acceleration, he said can compete with 525.
My top speed still the same. The pulley is exactly same size as stock, just that much lighter... some aftermarket not only lightened but also became smaller then will have bad effect... anyway, all is just based on me beginner's exp, so pls check wif other senior ppl as well.. :biggrin:
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
not to say rubbish... it has its benefits.... it reduces the mass of rotation... making ur engine easier to rev/accelerate....
shinrei
57
oic... there's many brand out there but which one is value for money?:hmmmm:
cnxnet
429
Thanks for the usefull reply, any member use that on mivec or V6 engine? what is the result:smokin:
GT_AUTO
3,501
71
1,648
K.Trg
www.facebook.com
to be honest,don't expect a lot of power for this mod.sometime it came back nil on
dyno.some claim to add around 5-6hp.the main thing is acceleration or pick-up.
like what sky sifu said.imagine shaving up to 2kg on ur crank pulley.it can turn faster
w/o much effort.that the reason y this thing was invented.
cnxnet
429
why come can gain hp some can not? we should choose the bigger pulley or smaller pulley or just same size with our original one? :confused:
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
is skimming flywheel same as lightened pulley? i meant the effect!:hmmmm:
more or less the same effect... depending how much u skim ur flywheel....
dongdong0507
40
thx sifu, i think the most important is the balancing, or else it will cause power loss right?
GT_AUTO
3,501
71
1,648
K.Trg
www.facebook.com
on flywheel,it's more noticeable cos f/w is damn heavy.were talking about 7-8kg of weight
compare to 2-3kg.i think those who install racing f/w should definitely install lcp.it will
make the engine rev easier.
Hey guys,
I'm new here...i need some help from the sifus here.
Anyone have install gearbox oil cooler to ur car ? How much would it be and where can i get one to fit in my CF4 ?
Thankz
