using a mythelogy one for 4g15 carburetted...worth every cent..ori one is about 2.3 kgs, mythelogy is 8xx gms only...
u can feel it more on the lower gears
from a review i did a few yrs back:
"peak hp has not changed much, some tests showed no increase, some 2hp only (need more testing to get average)...however, wat is more important is the power curve, it increases the whole powerband, at some points up to 4-5 hp...n it peaks earlier at around 270 rpm earlier...
now about torque, consistently it shows an increase of at least 6 to 9Nm...quite a fair bit...
not bad...now dont forget, the gtech's hp n torque readings will be lower than even the on-wheel dyno...this is due to the fact that im facing wind resistance in gear 2 (which is where the tests are focused on), so increases will be more obvious on the dyno..."
Cheers!
