my pickup suck!!!
kennyng
39
penang
my wira 1.5manual pickup is very suck even i changed to 1.6 clutch kit!!. anyone suggest what's problem for my car?
jinkl
4,623
376
3,183
there are 101 reasons why a turbo cant perform , go to experience mechanic to check up
my suggestion
1. compression test
2. ignition timing checkup
3. vacuum leak test
4. wideband AFR checkup
5. tune if needed
kurt shinoda
158
my suggestion
1. compression test
3. vacuum leak test
5. tune if needed
it's not turbo ma.it's 1.5:hmmmm:
tofu_manic
1,342
91
5,148
oh well, the advice is still applicable :burnout:
kennyng
39
penang
my suggestion
1. compression test
3. vacuum leak test
5. tune if needed
can explain more details? maybe i can DIY?
jinkl
4,623
376
3,183
nt tht easy
1. compression test - u dont have compression test tools
2. ignition timing checkup - u dont have timing light
3. vacuum leak test - do u have a compressor to check for leaks
4. wideband AFR checkup - you dont have a wideband sensor to check
wasteg4te
157
9
jb
clutch not improve your pickup.
it just for ensure no slip during pickup.
change engine lo
clanzkiller
1,394
27
1,648
engine shaking is bcoz of what?
pls be specifiy...
factors lead to engine shaking can be :
1.engine mounting
2.socket lossen
3.plug cable/spark plug problem
4.pressing clutch timing
5.idling not stable
bla bla bla..
So see in every thread, everybody complain about fuel prices, cannot buy performance car la, etc. etc. etc.
Alternative fuels also have what, like methanol.. our country sells it also..
Prices is about 1700+ (at the most expensive price, cheaper should be less than RM1 per litre) for 1250 litres (1 litre methanol is 0.8kg)
RON rating should be more than 110.. hahahaha..
Of course, this can't be so easily as the Stoich AFR for methanol is less than half that of petrol, so need to double...
