emanage tuning and installation
vteckiller
Supporting Merchants
1,606
34
nice and fast tune on the car today hehehehe
sure la must work fast and smart la.
further more thats the limit already.
add more timing also cannot up already..
max d la..
vteckiller
1,606
34
bro vteckiller
wanna ask ya
when im boosting my car jerks...and when im idling or cruising the air fuel is 10(checked using wideband)..one more thing...my idling is at 1.5k...cant adjust lower sumore...and it keeps fluctuating between 1.5k and 1.2k...
so if i wanna retune the emanage...will it solve my problem?
engine is 4g93p bot
hmmm i think should be no problems la..
can be done..a bit of tweaking here and there should do it..
bring over and see what i can do to help u out of your worries..
vteckiller
1,606
34
Hi Vteckiller,
Can emanage ultimate install at ER34 GTT auto tranny?
Whats is the package price for emanage ultimate?
Thanks.
can be done no probs..
but at the moment i dont have stock.
only in stock of blue emanage..
will check price and get back to u for ultimate.
y not just use blue one la..
can also ma:)
jinkl
4,623
376
3,183
max d la..
muahhaha, two tuners in one car , one seeing afr one with the laptop , lolx
red_line
171
Hi Vteckiller,
Really impress for fast reply.. haha..
Can the blue emanage do speed cut?
Thanks.
nafiiio
300
11
5,018
Bro .. I'm using Toyota 4age Blacktop.. and interested to install piggyback ecu.
1. How much do u charge for e-manage Ultimate + harness + installation + dyno tune + etc .
2. E-manage ultimate vs E-manage Blue for 4age 20v
JEH
243
I'm interested to know too!!
btw, i read that emanage doesnt couple well with 4age 20v ,can anyone share some insight to this statement?thanks
vteckiller
1,606
34
heheh that made life even more easier...;)
vteckiller
1,606
34
vteckiller
1,606
34
i've installed it on a couple of 4age so far..no complains so far..almost a year 1 car and another half a year i think..both cars still running fine..so i guess should be okay la..for 4age to use emanage.
vteckiller
1,606
34
redline
i think u need to buy a HKS SLD to remove the speed cut bro for your gtt.
JEH
243
so how much would the whole thing come up too for installation on a 4AGE 20V?
harness + emanage + tunning for 4age 20v...
thanks
popout
366
2
sifu vteckiller
i own a mivec auto and very high FC , now the fuel price hike too , i heard e-mnage can be tune to decrease FC it that true??
clanzkiller
1,394
27
1,648
sifu vteckiller
swt...since when e-manage become a fuel saver device ??
e-manage help to set your tuning to balance condition of air n fuel tat needed in the combustion chamber and also the requirement of your engine..
well,actually e-manage do help to decrease FC..but not in the way u mentioning..
like..oh i'm driving 3.0litre car,my FC very high,can e-manage tune my car to be like 1.5litre so tat my FC wil decrease?doesn't make any sense rite? :)
if u said...my mivec is running rich and i would like to make it running normal,can e-manage do it ? then the ans is yes it can
vteckiller
1,606
34
thanks
total all in all RM1450 best best price
vteckiller
1,606
34
sifu vteckiller
yup u are right can tune to decrease fuel consumption..
no probs can run afr at really light cruising 15.5 or so la..
then on half throttles 14.7 like that can la..
sure save fuel la..
then full throttle only run rich la..
so when u drive normally can save fuel..
yes emange can do that.
vteckiller
1,606
34
your 3L can be tune to run much much leaner to save fuel on half throttle and cruising..
but on full throttle is dangerous to run too lean..
so i am sure can save fuel also..but ofcourse not like 1.5 la.
maybe like 2.5 or 2.8L la..;)
kiran84
945
dunno
Hi vteckiller,
How about cam timing setting, can you do it too when you are dyno tuning to hit the optimum power band and Whp? are you good at it?
Pls do let me know Asap, planning to come soon oready to tune d E-manage as well............
Total cost?
thanks
vteckiller
1,606
34
Hi vteckiller,
Total cost?
thanks
YES I definately can set your cam for u.
would cost you additional RM150 just to set your cam pulleys to the right cam spec.
and rm300 would be charged for dyno tuning Emanage.
cheers :)
A Post Every 5 Mins
Need advise on this. Is it possible connecting I/F unit (HKS control unit) to Fcon-iS unit,so can monitor data on LCD (oil temp/press,exhaust temp,etc)? Now only display airflow,throttle,injector,etc. If possible what 'option' items needed and how to do the installation, OR just connect I/F main unit harness to F-Con iS OBD2 harness?:hmmmm:Any help on this is appreciated.
Car is S15 SpecR.
Thanks.
