help on diy install msd
erictan30
167
recently i just bought a msd and i have some several problem in indentify the correct wire to tap from the distributor..The wire i want to find is ignition coil(+) wire and Negative(-) but i could find it...not dare simply tap later the coil burnt...
Does any 1 know the wire as i'm using wira 1.6 sohc..really appreciate the help...Thanks...
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
bro... which msd u bought??... i have the installation guide for msd products (downloaded from msd website last time)... but cant seem to upload it to the server... u let me know which msd product u using i printscreen for u and post it up...
erictan30
167
no i just want to know which wire to tap from the distributor. i know i need to tap a positive(+) ignition coil wire and negative but there are so many wires there so asking wether anyone diy install b4
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
sorry just asking what is msd ?
multiple spark discharge
Welcome to MSD Ignition
ur engine using distributor or external coil??... if ur distributor only has 4 cables coming out (for a 4cylinder engine la), u will need to modify ur distributor... if it has 5 cables, means the middle cable connects to ur external coil...
basic wiring for MSD is..
RED - Switched 12 volt source.
ORANGE - Connects to coil negative.
BLACK - Connects to engine ground.
WHITE - Points or electronic ignition trigger
MAGNETIC PICKUP - 2-Pin Connector
VIOLET - Positive (+)
GREEN - Negative (-)
Note: The White wire and magnetic pickup wiring will never
be connected at the same time.
erictan30
167
i'm using stock setup the coil in together in the distributor same like saga..i just wan to know which wire that is connect to the distributor represent coil positive terminal and negative i just need to tap from there..then done:burnout:
other i already connect just this 2 only...by the way i'm using 6al
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
mayb this can help u clarify things...
MSD_INSTALL
im using Mits Lancer model A172 with engine 4G12 (1.4 SOHC Carb)
It'z posible to mod my original engine with any force induction? i mean bold on turbo, supercharger, eturbo or other type of Force Induction?
can discribe how to mod, which part of my engine need to be change or improve, how much it cost and wich workshop can do it?
Okey... Thanks... :unsure:
