Hi all! Anyone knows what can be done easily to door rubber linings so to produce solid thuds when door is closed as well as to protect door from slamming by strong hands? Rubber hose? Take the wira/satria doors as DIY examples. Thx!
autofoam....
Don't get it... What kind of product you mentioned..?
the other solution is to use aquarium o2 hose/pipe.
the small one.
and carefully insert thru the door rubber (usually the rubber at body for the door, hope u understand which rubber).
the rubber got small holes rite. they r spaces between each other.
insert thru the holes.
this will make the rubber more (hmm, how to say.. more fat/big?)
Sifoo.. Usually how much they charge for this.....?
Any problem in future.. In case Accident..?
usually above 1k... problem ah??... after accident, mudguard foreman will curse u to hell.. hahahaha...
single knock, automatically car condemn..haahahahahah
Really...?? Why bro..? Confused here....... :hmmmm:
because when ur whole chassis/car filled with foam, how u expect foreman to ketuk back for u after accident??....
Ya... bro, then nothing can be done right..? Campak lombong lo....... huhuhu..
Similar threads | |
