1997 Toyota Prado GX 2.8 Diesel
Kippo
263
hi,
Does anyone here know how to add turbo to original engine of 1997 Toyota Prado GX 2.8 Diesel ?
can you just bolt a turbo and if yes, what turbo model and make?
any other changes to be made eg. radiator, tuning etc.?
thanks.
Kippo
263
swapping with 1kz is expensive. It cost rm16k here.
i forsee that bolting turbo is cheaper.
swapping with 1jz or 2jz is not a wise choice since it will not be suitable in 4wd environment i.e. off-road.
huakenny
LB Performance
9,126
240
Kota Kinabalu
bolt on cannot stands longer....my fren BOT before here in sabah....engine block cracked when climb hill....
now with 1KZ....hassle free..original turbocharged engine....:_:
u can try to BOT, but low boost only
May 8, 2007
hi
GX 2.8 turbo bolt on?? why not? its not tat easy to blown up anyway. i done lots of toyota 3L engine which bolt on turbo but seems rarely got trouble. Those people who blown up might be they tune not right. any info pls email me
huakenny
LB Performance
9,126
240
Kota Kinabalu
can BOT, low boost lo.....unles u change internal n block to turbo one...
May 8, 2007
nolah, dont think u will believe anyway. we never change anything of de engine to turbo spec. actually those thing was same jus only de camshaft is bit diff. we boost up to 2.0 bar. believe or not?? up to u mate. im jus wanna recommend only.
believe or not up to u.
Kippo
263
can share how is it done and what type of turbo can be used?
cheers and thanks.
speedlover_2005
20
us
3L with turbo?? why not? i have done my 2L bolt on turbo n boost more than 1 bar with standard engine... no need to modify o change anything. even my fuel pump is also NA one... n find one throttle then buy one blow off... wooossshhh.....!!!
speedlover_2005
20
us
find toyota 2L turbo... model is ct-20... that is what u can easyly found in market... mine is also 2L turbo but it is ct-12 b.. same like 1KZ's turbo...
ccibai
59
msia
3L with BOT with intercooler n turbo fuel pump running 15psi standard internal for 4-5 yrs. No problem at all, same theory as petrol turbo, must hv enuff fuel n make sure it is not running lean n it should serve u well
The largest Ducati gathering in the country happened last Saturday, 16 April, as 110 Ducati bikes descended on Berjaya Times Square in Kuala Lumpur for the event that was organised by the Ducati Owners Club Malaysia and Next Bike, the sole distributor of Ducati in Malaysia, in conjunction with the Shell Advance 4T Roadshow Finale...
