Oh....in that case what can I do to make the grounding back to normal?
Old cars, sometimes the old wires resistant very high. Just get some thick grounding cables and ground a few points. My VR have extra cables to engine, firewall, alternator, and car body ......lol
Crank sensor have chg to a new one.
1st time the engine can start
After 2day dead agn.
How was it changed? Check the sensor contacts, wires, etc. If crank is strong and it doesn't fire, there's only a very very small number of things that can cause that. You better pray it's not your ECU
KHNG940413
668
56
johor bahru
Now what I guess is the ecu got problem. Ini kali mati lah.
what mati...yours only wira ecu.
mine is waja 1.8 ecu...just check online for the cost.When i encounter my weird problem i even bought another unit of 2nd ecu for about RM500.
Apart from bad wiring or grounding, bad connector can cause weird problem too. My friend blm has the check engine light blinking, speedo not working, and sometimes clock will reset. at first he tought its the O2 sensor and speed sensor needed replacement but a Proton tech said his mileages is too low for that to happened and the tech has never do replacement of the speed sensor and die2 said the speedsensor is very durable. One day i swap my meter cluster with him and everything was fine thus we conclude the meter cluster is fsulty. when we reinstall the old meter cluster.....everything works fine, totally no explanation what happen except the connector is potentially dirty(still dont make sense as its well protected behind the meter in the dash).
KHNG940413
668
56
johor bahru
My car now always have the speed & high voltage issue. I didn't go and bother it since my meter still can use. Juz when you go more then 100km/h it will pop up.
The crank sensor one I had changed a new sensor already.
Wah,waja ecu so mahal.
parakey
1,367
226
It was originally loose. After some time of using, it became looser and then occasionally lost connection.
parakey
1,367
226
P0501 & P0113 errors been there since last year. P0335 is your crank sensor. Did you previously change the crank sensor?
alcyon
800
153
543
Some times I think carburetor car is better, for longetivity that is....my old proton saga never gave these kinds of problems, sure the idling wasnt the most consistent, but it will always run.
Dear PPl,
Im having a big big question which i hope would reach to me back with the rightful anwser....my mechanic...has asked me to mix engine flush(Rm18) with my current used engine oil n drain them within 5 minutes after at idle speed to clean inner parts of engine....esp the valve n i think retainers(do reduce tappet sound when i cold start)....i just feel worried to do this cos when i smelled it was like petrol/thinner smell....Just damn freakin scard it might,might make my engine...
