Oh....in that case what can I do to make the grounding back to normal?
Old cars, sometimes the old wires resistant very high. Just get some thick grounding cables and ground a few points. My VR have extra cables to engine, firewall, alternator, and car body ......lol
Crank sensor have chg to a new one.
1st time the engine can start
After 2day dead agn.
How was it changed? Check the sensor contacts, wires, etc. If crank is strong and it doesn't fire, there's only a very very small number of things that can cause that. You better pray it's not your ECU
KHNG940413
668
56
johor bahru
Now what I guess is the ecu got problem. Ini kali mati lah.
what mati...yours only wira ecu.
mine is waja 1.8 ecu...just check online for the cost.When i encounter my weird problem i even bought another unit of 2nd ecu for about RM500.
Apart from bad wiring or grounding, bad connector can cause weird problem too. My friend blm has the check engine light blinking, speedo not working, and sometimes clock will reset. at first he tought its the O2 sensor and speed sensor needed replacement but a Proton tech said his mileages is too low for that to happened and the tech has never do replacement of the speed sensor and die2 said the speedsensor is very durable. One day i swap my meter cluster with him and everything was fine thus we conclude the meter cluster is fsulty. when we reinstall the old meter cluster.....everything works fine, totally no explanation what happen except the connector is potentially dirty(still dont make sense as its well protected behind the meter in the dash).
KHNG940413
668
56
johor bahru
My car now always have the speed & high voltage issue. I didn't go and bother it since my meter still can use. Juz when you go more then 100km/h it will pop up.
The crank sensor one I had changed a new sensor already.
Wah,waja ecu so mahal.
parakey
1,367
226
It was originally loose. After some time of using, it became looser and then occasionally lost connection.
parakey
1,367
226
P0501 & P0113 errors been there since last year. P0335 is your crank sensor. Did you previously change the crank sensor?
alcyon
800
153
543
Some times I think carburetor car is better, for longetivity that is....my old proton saga never gave these kinds of problems, sure the idling wasnt the most consistent, but it will always run.
yo noname,
wanna ask you
how much would it cost to replace a remote for my alarm
i am using the king leapord
was wondering if i can replace it with the king-dragon remote?
anyway, quote me the price for both the remote
cause my current one already both half dead
at first was one of the remote cannot disarm with ease, have to press for a few seconds then apply more preasure only can disarm
so i was using the other spare alarm till i dropped it
ehehe
not cannot arm with ease pulak...
