Show us your lancer/evo pics!
I read that cam sensor issues occur after replacing the camshafts. Often it's due to shoddy work. Oil leaks into where the sensor is or dirt/metal shavings interfere with the sensor's readings.
Hmm not sure. I saw myself when they're changing cams and seems proper. Btw the issue actually already existing a bit before but previously always can still start at least on the 2nd or 3rd try.
parakey
1,367
226
Nvm lah. Apply Chinese proverb. Money spent, heart at peace. :biggrin:
hope it helps and you can enjoy your modded evo asap. Let us know your latest gain after those mod.:driver::driver:
Btw, thx to you I have truly solved the hot starting issue. It's actually not cam sensor but the injector ballast. Not that it's spoiled but just must bypass because impedance became too high, hence when hot the injectors could not fire up.
Doesn't blocking the speedo and water temp kinda bother you?
It doesn't block the water temp at all, only blocks the Evolution logo! As for the speedo, can still see the needle moving on the dials, so still can see the speed. Anyway speedometer is not so important.
marsha1l_v6
666
130
543
your new injector high impedance?
IZME
Aug 20, 2019
12
75
Something is missing from this picture a turbo!!! Where can I buy a complete turbo kit for my 1995 Lancer Glxi 4g92 sohc?
Reactions: Izso
IZME
Aug 20, 2019
12
75
depend on the price of BOT or direct swap some serious power :biggrin:
you survey the cost first.
Not very worried about cost just would like a moderate power gain, it's one of my daily cars. The engine I overhauled which included new pistons, rings, crank, bearings, seals, valves, valve springs and cam. They were all OEM from Japan. I've already bought a new 609 MAF for a turbo not installed yet going to when the turbo is in. Just need a complete turbo kit now. I did notice in pictures the stock turbo 4g92 have a different intake which is short neck, mine has rather long ones.
Rather than buying parts separately and finding they don't fit, better get whole kit at once. Or Can try Speedworks, they have BOT......:driver:
IZME
Aug 20, 2019
12
75
I contacted Speedworks and they told me they only do custom tuning. That's what I want is a total kit, been doing lots of searching with no luck.
'(00): Over 40 pages long and 30,000views, Kevin Lee has managed to source his dream Honda S600 base, document his dedication in progress to restoring the classic Honda that started it all. Read on to find out just why he's gained so many loyal followers to his amazing project!
