Restoration of Satria 1.3
cIvIc_noob
62
Miri
Hi guys,
i have a one speed all the way wiper problem.
I've even bought and swapped out the whole wiper/signal control. problem still persists.
I read up more and it says could be a relay problem, could someone point out to me with a pic of the relay location?
i PM'ed a seller at shopee, mentioned that normally it is at linkage, I don't think so from my googling. So i went to look at the wiper motor side but couldn't find it.
I looked at the fuse box and i am confused.
So where exactly is it?
Hi guys,
Switch on your wiper or turn signal and listen for the relay 'tik2' sound. Trace the origin for that sound and you will find it.
I think its at driver side under the dashboard. It should be visible when u peek from the bottom.
Hi guys,
Engine bay I think. That's the only place that has those large relays for Wira.
sanekit
Dec 9, 2015
1,616
157
Hi guys,
it's inside the fuse box under your steering column. the box supposed to have a label on the cover.
Fuse box got relay? I think what bro. Izso mention in engine bay, the main fuse box have relays in them.....
sweelt
Nov 6, 2016
2,306
248
Key ON (not start engine), Activate wiper, listen to which relay clicking/ feel by finger. I use this method as last resort.
Hi guys,
Manage to find it?
cIvIc_noob
62
Miri
Thanks for telling Me there are relay there, but i Dont hear tik tik tik sound when i turn the wiper on.
Is there a possibillity if there was no relay there in the first place there wont be tik tik sound?
cIvIc_noob
62
Miri
Doesnt seem Like it bro , i googled the relay pic , And i Check engine bay Area at the small relay box on left And also the fuse box on right , nothing looks Like it .
cIvIc_noob
62
Miri
Oh use finger, haha ok i try find with This technique, but i am afraid if the previous owner removed it then there wouldnt be tik tik sound
cIvIc_noob
62
Miri
will installing steel braided brake hose increase braking performance? what type of brake pad is good and yet does not cost too expensive? i'm using a proton
