[DIY] Oil catch tank
Have mah! Fuel injected cars fuel filter is made of metal, but much more expensive
much more expensive in term of price gap but still cheap.
only thing u cannot see through the container.not sure if the filter material can stand heat as its design to filter petrol which will be lower in temperature.
some cheapo version uses tissue like material...so must bw careful.
Kevinho
94
Puchong
Yea lar
Easily > 100 ringgit
But dunno whether got use good stuff for filter material anot
Yea lar
Depends on car model. Mine around RM40 to 60, but like bro. gunnerzz mentioned cannot see inside. I still prefer my plastic ones......lol
Kevinho
94
Puchong
Lol, I guess I have joined the lazy gang. Not sure when my oil catch tank can finish making. I'll just put in the iswara fuel filter first.
abubin
22
Can I get a clearer picture on MyVI OCT implementation? Noob here and very interested with installing OCT on my 2006 1.3 MyVi. Very sorry to bro Izso as I don't see the host clear enough going from where to where and which one is intake and outtake.
Are you going to use a proper OCT can or one of those fuel filters?
abubin
22
Have not decided yet.
Is there a difference? Probably going to those ready made cans where some have 2 ports and some 3 ports.
i don't recommend what I did with the fuel filter. I found out later that it deformed and ended up clogging the inlet. It made it a lot worse. Better to use a proper OCT canister.
Vacuum is too strong. If the filter is always dry then its ok. Once the filter is wet with oil (which it will) this will cause it harder to suck thru the filter and the air will pressure will crush the filter.
abubin
22
Ahh..I see. Definitely do not want it to cause more problems than benefits. In that case, do you have any OCT canister to recommend? For MyVI, is something like this good enough?
Please help me all the taiko here.
I wanna ask what is the used for centre bullet?If install more than 1 bullet what is the effect of the car?
What is the used of short shifter?
What is the used for oil catch tank?Can be used in NA or turbo car?
What is used for trottle body?
Please help me on this
