Rpf1 ori 15inch offset 35 cannot fit in vios xp150,anyone can help?
jeffryfei
15
I have 1 set ori rpf1 15 inch et35 4 x 100 but cannot fit in my xp150 vios,the brake caliber just touch the wheel,any way to make it clear?can i sand my caliber to fit it?
Huh, ori RPF1 cannot clear the brake caliper? Is it stock calipers or already modified to bigger ones? How much is the touching and where is it touching, is it on the spokes or the wheel rim?
jeffryfei
15
Ori caliber,touch the wheel not spoke...no modified anything yet just want to put in the rim to look nicer
Touch spoke can add spacer, touch wheel then cannot already. But ET35 plus spacer will come out of wheel fender
mADmAN
1,840
547
RPF1s has a very small wheel barrel by design......not the first ive heard about clearance issues between the barrel and the caliper.
solution: change rim HAHAHAHAHAHA
But if original caliper cannot clear rim designer should be shot, how to sell........hhahhahahhaha
Hmm rather strange, that means the caliper also barely clears the stock 15' rims, is it? If the touching is just very slightly grazing the wheel barrel then you can consider just grinding/sanding just some small section of the caliper surface where it touches. If it touches too much until the wheel really got blocked by the caliper then no choice but to use other rims.
+35 offset is already plenty out....
u sure the wheel is ori rpf1?
i suspect it was some shit replica copy fake imitation
mADmAN
1,840
547
well... RPF1 is a wheel inspired from their F1 wheels....so i guess they had more of a performance car in mind... dont think they were thinking about god-level cars.....just performance-oriented cars hahahahah
clears stock B16A brakes fine.
All,
Planning to get some stuff from overseas and I was stuck as they ask which engine I'm using now. When I told them I'm having a Mitsu E2, they are not sure and ask me whether it's a 6 bolts and 7 bolts engine...????
So my questions, what is 6 bolts and 7 bolts? Which engine is using 6 bolts and which is using 7 bolts?
vr4, e1, e2, e3 - 6 bolts???
e4 and above - 7 bolts????
Thanks
