Need step by step picture guide to replace Myvi2005 from front absorber mounting
I would not use straps. The spring is a pretty solid and strong metallic item. Straps are threads sewn together. The likelihood of the strap snapping is high if worn out or poor quality.
But engineering perspective - yes this will work. It's cheaper to get the compressors though. Ratchet straps aren't exactly cheap either.
Look at the video properly, he is using the straps in addition to the spring compressor that could not completely compress the springs. so the straps are compressing only one ring of the springs.
https://youtu.be/l-zDt9FGJi8
This is the difference..pretty interesting to learn this. izso you knew about this?
I love it when people tell me that their Sumo engine oil, their "racing" oil, or their JTX engine oil damn good.
A glimpse inside Mobil 1, and I believe the big boys like Shell, Total, Castrol would have something similar in terms of R&D.
Oh, and keep your "race proven" engine oils. Race engines are rebuilt annually or after EVERY RACE. So unless you rebuild...
