Powerful RWD, his will be staggered......Good choice going with the 17'. How wide? Square or staggered fitment? Hammans should be made by OZ Italy.
8jj and unfortunately not staggered rim size. I'll be on the lookout for staggered rims though. Tyres I'll be sticking with my current tyres and only consider what to do after I wear them out. 245/40/17 rear and 235/45/17 front.Good choice going with the 17'. How wide? Square or staggered fitment? Hammans should be made by OZ Italy.
245 can take that amount of power?245/40/17 rear and 235/45/17 front.
Need good rubber should be ok, any wider tendency of aquaplaning is greater.....245 can take that amount of power?
Hmm should get wider rims, at least 8.5jj all round or staggered 8/9jj. Should just use 235/45/17 for all now. 245/40/17 is too small in diameter and sidewall a bit too thin like mine (only 9.8cm sidewall height). If go staggered 8/9jj, then can use 225/45 + 255/40.8jj and unfortunately not staggered rim size. I'll be on the lookout for staggered rims though. Tyres I'll be sticking with my current tyres and only consider what to do after I wear them out. 245/40/17 rear and 235/45/17 front.
Square is ALWAYS better. ALWAYS. Staggered is for the looks...if you're into that.. sure..8jj and unfortunately not staggered rim size. I'll be on the lookout for staggered rims though. Tyres I'll be sticking with my current tyres and only consider what to do after I wear them out. 245/40/17 rear and 235/45/17 front.
He wants wider rear to hold it's power, but cannot fit wider into the front due to steering....lolSquare is ALWAYS better. ALWAYS. Staggered is for the looks...if you're into that.. sure..
Staggered induces understeer.
RWD needs stagger? BS. Just get wide enough tires for both front and back and you're done.
Yes, coz the rears usually can fit much wider than front if you need as much rubber to maintain traction, hence that's why staggered.He wants wider rear to hold it's power, but cannot fit wider into the front due to steering....lol
Some FWD doing the opposite to counter under steer......lolYes, coz the rears usually can fit much wider than front if you need as much rubber to maintain traction, hence that's why staggered.
Yes I've seen that too on some FD2Rs setup. Must be some hardcore drivers.Some FWD doing the opposite to counter under steer......lol
Well, front track already wider then the rears. Only thing it looks funny with the front bigger and wider......lolYes I've seen that too on some FD2Rs setup. Must be some hardcore drivers.
wait.. 245/40/17 is smalll?Hmm should get wider rims, at least 8.5jj all round or staggered 8/9jj. Should just use 235/45/17 for all now. 245/40/17 is too small in diameter and sidewall a bit too thin like mine (only 9.8cm sidewall height). If go staggered 8/9jj, then can use 225/45 + 255/40.
What tires are those btw?
245/40 and 255/40 will definitely cost much more......lolwait.. 245/40/17 is smalll?
Damn. And here I was thinking it was too wide. Stock for E36 17" is 235/45/17 apparently.
I want 8.5jj but I also don't want any stretching. Plus tyres get more expensive after 235/45 la.
Rears are currently AD08R and front are the ones I really want to change out - Achilles ATR Sport. Too noisy la this combi.
TQ taiko waja turbo-some-say-fasterest-waja-in-subang-and-usjWahh now only I know the lejen bmw 1jz got so much history. All the best in fixing all the gremlins!
Why does that sound so much like PCK?TQ taiko waja turbo-some-say-fasterest-waja-in-subang-and-usj
dunno him, i no yellow boots punWhy does that sound so much like PCK?
Nightstalker was one of the initial people who introduced me to the world of turbo and launch control. In a FWD Waja built by his own hands no less.Why does that sound so much like PCK?
I small fry only with small turbo and small car. Exhaust pun senyap sajaHighly admirable
Launch control tu apa? No idea what's that worr :flute:Nightstalker was one of the initial people who introduced me to the world of turbo and launch control. In a FWD Waja built by his own hands no less.
