1jz E36 BMW frankensteining
I opted for the 17". Super rare size! Most Hammans are 18" and above. Managed to nego to 1.8k. Not sure about OZ Italy though. They should be if original. I see the Hamman label but don't see OZ or Made in anywhere in the etching.
Good choice going with the 17'. How wide? Square or staggered fitment? Hammans should be made by OZ Italy.
8jj and unfortunately not staggered rim size. I'll be on the lookout for staggered rims though. Tyres I'll be sticking with my current tyres and only consider what to do after I wear them out. 245/40/17 rear and 235/45/17 front.
Hmm should get wider rims, at least 8.5jj all round or staggered 8/9jj. Should just use 235/45/17 for all now. 245/40/17 is too small in diameter and sidewall a bit too thin like mine (only 9.8cm sidewall height). If go staggered 8/9jj, then can use 225/45 + 255/40.
What tires are those btw?
ixeo
4,788
3,080
KL, Malaysia
Square is ALWAYS better. ALWAYS. Staggered is for the looks...if you're into that.. sure..
Staggered induces understeer.
RWD needs stagger? BS. Just get wide enough tires for both front and back and you're done.
He wants wider rear to hold it's power, but cannot fit wider into the front due to steering....lol
Yes, coz the rears usually can fit much wider than front if you need as much rubber to maintain traction, hence that's why staggered.
just wanna share, last week when i walk at car care section at carrefour i saw this microfibre cloth. i bought it - a pack of 2 pcs cloth. size about 8"X9" i guess. at RM12 if i not mistaken.
this cloth is very good for ur car, esp if u wash car urself. normally after wash, i use hand-towel to wipe but the problem is the towel will leave a fabric dust on the car. i found out:
1. it very soft - it will not leave a swirl mark. i oso use it for express polish.
2. it absorb water well - good...
