1jz E36 BMW frankensteining
15,390
Good choice going with the 17'. How wide? Square or staggered fitment? Hammans should be made by OZ Italy.
8jj and unfortunately not staggered rim size. I'll be on the lookout for staggered rims though. Tyres I'll be sticking with my current tyres and only consider what to do after I wear them out. 245/40/17 rear and 235/45/17 front.
Hmm should get wider rims, at least 8.5jj all round or staggered 8/9jj. Should just use 235/45/17 for all now. 245/40/17 is too small in diameter and sidewall a bit too thin like mine (only 9.8cm sidewall height). If go staggered 8/9jj, then can use 225/45 + 255/40.
What tires are those btw?
ixeo
4,788
3,080
KL, Malaysia
Square is ALWAYS better. ALWAYS. Staggered is for the looks...if you're into that.. sure..
Staggered induces understeer.
RWD needs stagger? BS. Just get wide enough tires for both front and back and you're done.
30,002
He wants wider rear to hold it's power, but cannot fit wider into the front due to steering....lol
Yes, coz the rears usually can fit much wider than front if you need as much rubber to maintain traction, hence that's why staggered.
15,390
wait.. 245/40/17 is smalll?
Damn. And here I was thinking it was too wide. Stock for E36 17" is 235/45/17 apparently.
I want 8.5jj but I also don't want any stretching. Plus tyres get more expensive after 235/45 la.
Rears are currently AD08R and front are the ones I really want to change out - Achilles ATR Sport. Too noisy la this combi.
30,002
245/40 and 255/40 will definitely cost much more......lol:biggrin:
Nightstalker1993
267
130
Subang Jaya
Highly admirable :congrats:
I small fry only with small turbo and small car. Exhaust pun senyap saja
Nightstalker was one of the initial people who introduced me to the world of turbo and launch control. In a FWD Waja built by his own hands no less.
Launch control tu apa? No idea what's that worr :flute:
And nola not exactly everything by my own hands. Intercooler pipe, exhaust and those welding stuff all still need workshop do for me. Also, all the heat shield also not done by me huhu
21,956 units of the 3rd-gen City (2009) and 1680 units of the 2nd-gen Jazz (2009/2010) will need replacement of the lost motion springs and retainers within the engine which may bend or snap over time which results in irregular engine noise and could cause the engine to stall. As a countermeasure, Honda Malaysia will replace these parts at...
