Tire Price list Zth
Yes, if your rear is 275/35/18, then your front should be 245/40/18. 245/45 is too thick so overall diameter with 18' is too big. I use 245/45 before but on 17'. How wide are your rims? If still max 8.5/9.5jj then next change can use 225/45/18 and 255/40/18, cheaper and more comfortable coz thicker profiles. Alternatively if can still fit, 235/45/18 and 265/40/18 are even better.
Ah, they're new tho. Still got a long way to go. I'll def chase for comfort for the next change hahaha and uniform brand throughout, fronts are Michelins and back are Continentals. From what the guy told me, I will have a slight different feel in handling. Is it true?
Oh and 18x9 front & 18x10 I think.
You're using 9jj wide rims right? If so, should not use 225, need at least 245, so best to use 245/45/17. if your rims are only 8-8.5jj wide then use 235/45. I would suggest the Hankook V12 Evo2 or S1 Evo2 coz they're value for money.
nope, super advan racing for 17', should be 8 jj if i'm not wrong.
i saw many good reviews about yokohama advan fleva v701 but i can't find any in johor.
Yeah, Hankook V12 Evo 2 seems to be a good and cheap replacement.
prefer comfort and less noisy as compare to my RE002.
V12 should be made in korea only?
225/45 to 245/45 cannot go in loh, wheel arch sure kena already....lol
any good recommendation for tyres that range around RM300++
prefer comfort and quiet.
currently on RE002, DOM in 2014, need to change if i not wrong?
size 225/45/17 x 02, or 225/50/17 but need to change 4 in total.. :sleep:
Good tyres 225/45R17 at around RM300 will be tall order......lol
2014 tyres should be still good, just check physically for fine crack lines on the pattern and sidewall. If none, still can use pass 4 years....:driver:
Wah so wide! In that case must use minimum 245 width for the front, so then 245/40/18 + 275/35/18 should be the best staggered tire sizes for you.
Hmm then use either 225/45/ or 235/45. IMHO 235/45 is better if can still fit but will be more expensive.
Btw I just changed rims and tires for my wife's Livina and the front tires are the V12 Evo2 size 225/45/17. I just tested it during heavy rain and got lots of big puddles just now and it performs very well! Steering was damn steady and I was overtaking cars left right and center as they're all too slow. :driver: So this is a good tire for aquaplaning resistance but haven't test much cornering yet in the wet. Later once dry I will also feedback some more how they are.
waiting for you, as you are the tyre guru, it been a long time since i bought 17' tyre.. :rofl:
so far, no cracks for RE002, just old and noisy.
i guess i could still live with it then.
i got a question, tyre guru.
if i have a particular tyre that always losing it's pressure, while the other 3 are fine.
what is likelihood to happen over here?
alignment? tyre leaking air?
yeah, 235/45 is costly..
i'm actually thinking of switching to 225/50 or 55 for more comfort but if i were to switch, i got to change all 4pcs..
mind me asking, how much you pay for V12 evo 2?
was quoted RM380 + GST in johor..
i find it quite expensive..
RE-002 are good tyres, if still grip well might as well keep for a while longer.
Tyre leak nothing to do with alignment....lol
First check for puncture. A nail or screw embedded in the tyre will have slow leak. If there are no puncture, next you need to check the area where the tyre fits the rim. Lay it flat on the ground apply soapy water around the tyre where it fits to the rim. Do for both sides. If still no leak then check the valve area, also the dust cap, see if anything inside. If all fails to have any leak, last resort submerge whole wheel in water. If still no leak, then I also cannot help you.....hhahhahahha:rofl:
Yup, 225 to 235 probably ok but tyre more expensive.
225/50 can but 55 will be too high.
If change 2pcs, put new to the rear to finish the old one up front, but best is all 4pcs.....lol
225/45R17 V12Evo2 for RM380 ok mah.....:driver:
i think i probably have to send it for the submerge test, there's nothing on the tyre that i can see.
55 will be great for comfort, i guess the max that i can go is 50 only.
good thing is i'm on adjustable, hence still quite flexible.
mind me asking, why new tyre on rear?
mine is a FWD, i always see a lot of debate on this.
as bro vr mention, new to the rear to finish the old one up front, to speedup the wear on old tyre so u can change to new one fast..:driver::smokin:
anyway, how good is landsail, i saw 9th gen accord use it,evoque use it..merc (w212)...:smokin: which model landsail are good?
Yes, stick with 225/50/17 if want more comfort coz 225/55/17 is too big already for your car. Even my car also only use 225/50/17 last time.
If 225/45/17 V12 Evo2 should be able to get for just over rm300, see example below:
https://www.mudah.my/Tayar+Baru+Hankook+V12+Korea+2254517-59818346.htm
Yup... I love wide hips :biggrin: what happens if I go for 275/40 instead?
That size will be the same diameter as your current 245/45/18, so will be 2.8cm bigger outer diameter! Surely will be more comfortable coz already 11cm sidewall but not sure can fit or not on yours, plus acceleration and FC will not be as good.
Guideline in general is new at the rear because it's safer especially in the wet as the front will aquaplane first and therefore you'd understeer first which is easier to recover instead of oversteer. However if your other older pair are still in pretty good condition, say >60% then IMHO better to put the new at the front to even out the wear, then rotate regularly afterwards so later all 4 finish at the same time. With the new at the front, you also will feel your steering back to more responsive plus the comfort of new tires. If you're a pretty good driver also, should be no issue with a bit more grip at the front, in fact they would prefer such feeling of sharper turn in from the new tires. So in short, it depends. :biggrin:
If you have read my post like bro. marshal, he want to change tyre size, so that is why new to rear and old to front to wear them off, so that he can change another 2 to even them out......lol :biggrin:
https://www.youtube.com/watch?v=gSz7cm6MwH0
The debate is shown in above video. However it all depends how bald are your old tyres. More than 50% and less than 50% will give different results......lol:driver:
what do you guys think about UC6 and dunlop D05?
Both made in malaysia.
at Lazada.my, UC6 is going for around RM365 for 225 50 17 but no delivery
Dunlop D05 is going for RM340 with delivery..
Those guys who stay at KL, very lucky..
you guys always get to enjoy good tyre pricing..
Dunlop D05 quite normal tyres only.
UC6 is in between CC6 and MC5, so sort of entry to mid tyre only. If want to try Conti, go for their new MC6, now categorized as UHP already....lol
https://paultan.org/2017/10/04/continental-maxcontact-mc6-launched/
A Post Every 5 Mins
What do you get when you put 30 car enthusiasts and media, 280bhp of power in a lightweight chassis, dozens of pylons and a sun-kissed open space with intermittent sea breeze? An adrenaline-packed, fun-filled afternoon of course! As part of its already packed Leg 1 of Shell Helix Invasion Tour 2011 itinerary, the Shell-Zerotohundred collaborative event also included an autocross challenge...
