saufeq
Hi, it that a problem to put different size tire Front (205 /40/R17) and rear (205/45/R17) ? Mine fwd
The goal is to change both tyres to 45 but due to tight budget I'll take 2 first.. also I worried about esc or speed sensor get damageIt’s terrible for you, because FWD understeers already. Wider rear tires just makes it even worse. Plus different sizes just gonna mess up the balance of the car.
what is your goal? Looks? Then do whatever you
If just to use temporary, then can. I have used 205/50R16 front and 215/45R17 rear, when in transition from 16" to 17" rims........lolThe goal is to change both tyres to 45 but due to tight budget I'll take 2 first.. also I worried about esc or speed sensor get damage
Sounds like lotus car has 16f, 17r tires. HuhuIf just to use temporary, then can. I have used 205/50R16 front and 215/45R17 rear, when in transition from 16" to 17" rims........lol
Mitsu VR, like I say temporary no problem. Lomg term you cannot rotate the tyres is another problem .....lolSounds like lotus car has 16f, 17r tires. Huhu
I dont think the sensors will get damage as they are designed to just measure and feedback data. If it detects any abnormality it will show up as error (warning light) but this does not mean the sensor got damage.The goal is to change both tyres to 45 but due to tight budget I'll take 2 first.. also I worried about esc or speed sensor get damage
I don't think they will be damaged but the ESC behaviour might be a bit different if provoked, not sure.The goal is to change both tyres to 45 but due to tight budget I'll take 2 first.. also I worried about esc or speed sensor get damage
Achilles I don't think suitable for me caused I'm kinda wild driver. Hankook v2 already try long last but does not grip much.. right now I'm using mc6. I like it. Perf/touring quite balance.. price too..why not getting a normal tyre like Achilles or Hankook... so that you can same size...
Hankook V2 mid range only, need V12Evo2 above.....Achilles I don't think suitable for me caused I'm kinda wild driver. Hankook v2 already try long last but does not grip much.. right now I'm using mc6. I like it. Perf/touring quite balance.. price too..
Achilles ATR sport it not that bad. Experienced it on a Suprima before, i believe its HP category.Yup in my opinion.. entry level is enough for daily driving..good traction.. or maybe can put different type like ps4 at front, mc6 or ecopia for better. Just opinion
MC6 should be better than ATR Sport, not below ATR Sport.Achilles ATR sport it not that bad. Experienced it on a Suprima before, i believe its HP category.
MC6 and Ecopia are tayar pergi pasar compared to PS4 and ATR Sport. Not saying its bad but its well below Achilles ATR sport.
I would go for VR2 suggestion by going for all new alternative brand of HP tires.
Ecopia is entry level... how can compare to PS4? Surely you can get all Ecopia the same size... with just the price of 2 pcs of PS4Yup in my opinion.. entry level is enough for daily driving..good traction.. or maybe can put different type like ps4 at front, mc6 or ecopia for better. Just opinion
Thread starter | Similar threads | Forum | Replies | Date |
Touring tires review 2020 by tyrereviews.co.uk | Wheel And Tyre | 8 | |
I | Where to get rally tires? | Wheel And Tyre | 5 | |
New Tires : Front or Rear | Wheel And Tyre | 56 | |
K | Choosing value or price for a tires ? | Wheel And Tyre | 16 | |
K | Tires selection. | Wheel And Tyre | 40 |
