Discuss About Your Car...
stutzedward
3,416
561
The original setup is already very well balanced as the 50:50 weight distribution handles just like a normal street car that is tuned very well. So using stock absorbers doesn’t mean it’s less better than aftermarkets. Moreover, it already has Eibach coils, which is meant to be used with stock ansorbers.
Nice BBK......:driver:
Original absorbers you get better ride......lol:biggrin:
s.marz
261
18
28
Ahhh I read that as coilovers, I'm guessing if you are not tracking it then those eibach is more than enough :driver:
stutzedward
3,416
561
One more reason. Original absorbers will have longer intervals for replacement compared to adjustables need for rebuilds. Just want problem free for the next 5 years.
s.marz
261
18
28
But it's cheaper to rebuild coilovers than replacing absorbers, no? for each suspension, it'll cost you round 250 to rebuild while new OEM cost bout 600 each.
I've read forums where the KWs will run about 100k KM before needing to rebuild so that's about 4.5 years (according to my daily commute.)
Yes better in terms of comfort and reliability. :)
With the current situation at my area, I really miss the OEM set up... Road is bumpy and terrible af due to construction of the new DUKE (I think.) :banghead::banghead::banghead:
If it drives me crazy anytime soon, I'd switch back to OEM MSport. :mad:
I feel you. My first set were Top perfect rears with original front rebuilds, meaning original absorbers cut open and rebuilt. They were good and able to handle my 200 horses, and yet still comfortable. Then years later, friend offer a set of D2 coil overs, and since my old set were due to rebuild just take over this D2 set. Woh! they are really stiff, might be good for track but for daily, really pain to the butt, but when fully loaded the ride is still good.....lol
s.marz
261
18
28
Yea pretty much, I am always alone 95% of them time so I always feel it ahhaha.
But take it to the B-roads damn I am in love again, suddenly all those annoying bumpy and rough road is forgotten :rofl: a constant struggle to keep my sanity in check.
ixeo
4,788
3,080
KL, Malaysia
Yeah why stock absorbers? Could get stock-spec absorbers, but with mono-tube, like Bilstein B8 for your Eibach lowered ride. B6 is suitable down to 30mm drop.
Those mono tube units are beefy.
stutzedward
3,416
561
I have bad experience with adjustables in my Airtrek perviously. Even though there were no leaks, I got unwanted knocking sounds from the top mount on bricked road surfaces. It's annoying when you hear tick tick. Using stock original absorbers can completely rule out this problem.
Additionally, I don't go track or racing anyway, and I use this for my family. So lowered with Eibach + stock absorbers is the best choice as advised by my mechanic.
s.marz
261
18
28
Yea the B8 sounds promising without compromising comfort, might downgrade to B12 (B8 + eibach pro kit). But I guess it's better to test drive one of those first :driver:
s.marz
261
18
28
I had that problem too and apparently it was just bad top mount. Replaced both front and its all good now!
stutzedward
3,416
561
Yes it’s annoying right? Glad you had yours fixed.
I like the new suspension system. It’s comfortable and yet handles brilliantly. So it’s what I really wanted.
Maybe should redo my old suspension and use back.......lol:biggrin:
stutzedward
3,416
561
Apparently you can still rebuild your stock suspension. It can be cut open and modified as a screw down cap to access to the internals. The external absorbers tube won't spoil unless you dented or bent it. That's what my mechanic did to my Ralliart suspension in my Airtrek previously because it leaked. It was rebuilt and works wonderfully.
Some even go to the extent of modifying height adjustables and it's not difficult to mod actually.
The Marketplace Top Posts
Hi! Anyone spotted this car, please give a call at 0193824143 or 0123737669
Details
Champagne in colour,GT Wing, bronze 16inch rims,car lining sticker
Car lost on friday at old klang road and heard a few tip-off's about it at a few areas but still can't find it..Please give us a call if you found any abandoned car with the details above or seen it on the road..thanks
