top overhaul
I raise my VR back to original height, better probably because made for rally......lol
kurt_629
872
54
johor
*face palm*
sent the ride back to workshop..
engine leaking when boosting..
water found in engine..
clutch plate need replacement..
wiper motor is dying..
need new battery as current is 3 years old..
*face palm*
Number 1 what is leaking?
Number 2 looks bad......:banghead:
lsm1991
1,469
185
*face palm*
that escalated quick...
kurt_629
872
54
johor
it should be from engine block, need to some work, forgotten what its actually called.
yeah. running on no/Min engine oil.
Lucky nothing happen.
gonna waste another 2k at least..
i think i have spent at least RM10k for the repair..
some time, i feel my wife is right. i should just sell away the car..
lsm1991
1,469
185
*pats back*
am also dealing with some very annoying stuff here....
car idles rough, wont die but it keeps hunting. suspect
-vaccum leak
-map sensor ko (but i just tapped in and tested the voltages the other day, moves up n down but unsure if correct)
-wiring from map to ecu (oh this will be hell to check)
-ecu itself ko (kinda unlikely i guess)
AND car throws me an error, "32 Vacuum sensor".... yeah this gona be fun
what was leaking?
kurt_629
872
54
johor
what happen? its not your daily car kan?:smokin:
nope, lucky it's not..
it's a long distance car.. 1 year, probably clock 5-7k max..
initially, was leaking and turbo choke.
now, still leaking but turbo resolved.. more power
then its white smoke.. despite i just did an overhaul in April..
very disappointed, feel shameful..
so, send back to workshop..
lsm1991
1,469
185
fuyoh.... my DAILY driven car clocks just over 4k per year. ur week end car also clocks the same mileage ahh!!!!!
marsha1l_v6
666
130
543
always pedat to the floor at toll booth ka?
using metal gasket? which oil leaking?
how far per day you travel...my daily clock at 7k 6xth day:smokin:
I drive an Iswara but I can't remember the year unless I check my car card at home.
It is a 1.3 A/B manual model older than the LMSS/LMST and I bought it when the limited edition silver LMSS was introduced.
The car is not actually modified, but I started to use K&N open pod air filter, NGK Platinium or G-Power number 6, fully synthetic engine oil & regularly change the oil + filter every 5,000 kms as soon the car has clocked 10,000 kms until today but everything else is stock standard...
