Slim spare tyre for old Satria
jebatdex
430
18
Skudai, Johor
Can I replace my full size spare tyre with slim spare tyre like those in those modern cars? Mine is 1996 satria. So can reduce some weight. appreciate your input
Why not? Main thing whether you can find one the fits your PCD and with tyre around your original tyre diameter. Must remember space saver spare tyres are take you home tyres and should be not driven over 80kph
jebatdex
430
18
Skudai, Johor
i found this in the marketplace:
http://www.zerotohundred.com/newforums/showthread.php?t=218587
I guess this one is correct, but from 2004. Im still using the original tyre size and rim, 14" one. Noted on the space saver tyre constraints.
RM80 to 100 only, prices are not bad. On calculation looks like you need the 16" one which is closer to your original diameter. Maybe can try putting the spare next to your original tyre to check overall diameter size.....:driver:
jebatdex
430
18
Skudai, Johor
ok.. if im using 14" tyre, meaning the spare tyre rim size would be bigger right, thats why u said 16", because the spare tyre is thinner. ok, will do that, thanks. maybe price now could be up to RM120
Your original are 14", if stock size is 175/65R14, upgrade size will be 185/60R14. I saw from your link the space saver spare are 115/70, so is very narrow meaning sidewall also less so have to make up with rim size....:driver:
Great day guys,
This morning I woke up and was thinking about doing away the stains on the headlights with little or no cost and was thinking about the those sale person at Tesco offering product that can clean it. Always refused those pestering salesman as the stains on the headlight was only minimal and only on one side. Furthermore after you have done polishing the headlights the stains won't come back instantly and the product that we bought might be expired then. So I set out to DIY my...
