Slim spare tyre for old Satria
jebatdex
430
18
Skudai, Johor
Can I replace my full size spare tyre with slim spare tyre like those in those modern cars? Mine is 1996 satria. So can reduce some weight. appreciate your input
Why not? Main thing whether you can find one the fits your PCD and with tyre around your original tyre diameter. Must remember space saver spare tyres are take you home tyres and should be not driven over 80kph
jebatdex
430
18
Skudai, Johor
i found this in the marketplace:
http://www.zerotohundred.com/newforums/showthread.php?t=218587
I guess this one is correct, but from 2004. Im still using the original tyre size and rim, 14" one. Noted on the space saver tyre constraints.
RM80 to 100 only, prices are not bad. On calculation looks like you need the 16" one which is closer to your original diameter. Maybe can try putting the spare next to your original tyre to check overall diameter size.....:driver:
jebatdex
430
18
Skudai, Johor
ok.. if im using 14" tyre, meaning the spare tyre rim size would be bigger right, thats why u said 16", because the spare tyre is thinner. ok, will do that, thanks. maybe price now could be up to RM120
Your original are 14", if stock size is 175/65R14, upgrade size will be 185/60R14. I saw from your link the space saver spare are 115/70, so is very narrow meaning sidewall also less so have to make up with rim size....:driver:
hye there,
im on my way to port polish and grind valves of my 4ag 16v head...
already put the head out...
anyone got any website or anything that i use as refferal. if wanna port how the port should be etc... also what item and chemical is good to make my oily head shining again..
thanx a bunch..
