Perdana V6 Community Forum *
kimix
Mar 29, 2017
25
Klang/Selangor
any difference on the FICD?
____________________________
No improvement at all.....must b d throttle body,.....
Wht is next cos of action,..would it b throttle body issue?...
If its t.b,..would it b bes2to servis d t.b or change a 1/2 cut units(cos rm350 wt 2 weeks warranty)?...
or buy new one cost rm500 wt 2 mth warranty....
NeuroOne
WFH
2,078
181
Putrajaya
service it first
humongousgravy
189
Seremban
Guys I wanna ask. Who is on F312 manual gearbox? What is the rpm at 100km/h ane 120km/h? Mine is 3k at slightly less that 100km/h. Just wondering if this is normal.
NeuroOne
WFH
2,078
181
Putrajaya
i think thats quite normal for F5M312, bcoz of the shorter gear ratio
Any suggestion piggyback?standalone?
depending on ur objective
if u r looking to be horsepower house, a drag or track machine, then go for standalone
if its gonna be a daily ride with good amount of power, i think piggyback is enough
a few friends of mine with 300whp uses piggback only
piggybakc easy install and easy to manage coz u r still using the standard wiring and ECU
only using the piggyback to 'cheat' the ECU a little
so it goes back to ur objective..
humongousgravy
189
Seremban
Alright thanks guys. Short ratio it is. Thinking of what else I can do. Haha. Gonna make a custom gear boot to fit first thats the first objective. Maybe make a matching handbrake boot with it together.
spawn_net
147
27
Thanks A lot Bro.. Now I'm very clear. Yes indeed my target is to get it at 300bhp. :wavey:
kimix
Mar 29, 2017
25
Klang/Selangor
Is engine flush really works?....
How much power will it restores....
Wht is d benefit besides power gain?....
kimix
Mar 29, 2017
25
Klang/Selangor
Hi all
The throttle body seems had no improvement after :
1) done d throttle body servicing & its timing go up & down again(particularly on the hot day driving)
2) changed used FICD, also no help....
Can a Throttle body can be repaired?...
What is my next solution?....changed a used or new TB?.....
Thx
I
30,002
_________________________________________________
Bro....wht is d best interval to do flush?...evry 50,000 km?
If your oil change interval on time you actually don't need to flush. Beside chemical flush you can use cheap lighter viscosity oil to flush also.
hi everyone in zth i'm recently install this engine 6A12 TT in my perdana, and now its completely standard and original, just need so info on how to upgrade this mac ? wat should i do first? any sifu or expert can help me ? thank you very much.
