Airtrek Turbo Gearbox
biao
348
24
perak / ipoh
Dear All Sifu,
i need all your advice and opinion.
i suspect my gearbox KONG already.
on yesterday i feel my car have jerking and have metal sound came out. first i suspect my turbo kong because when i step the pedal just have sound running low speed, release pedal sound more loud. jerking awhile then no more already.
so this morning i try again, same method when i step pedal just have sound,release same.
but when i go fast totally no sound came out. then i suspect is my gearbox kong. why i suspect because i try switch to pedal switch, gear 1,2,3 sound came out, change til gear 4 then no sound.
so this can proud is gearbox KONG? can repair? how much the cost? or change it? if change, change half cut condition or change the recon gearbox?
biao
348
24
perak / ipoh
Dear All Sifu,
any one can advise?
4gbanger
1,958
386
1,683
Johor/ShahAlam
if the gearbox really kong, it will turn to limp mode. u can only run on 3rd gear. but now all gear can engage, only sound then it might be the transfer gear or long shaft.. u have to get it check.. go to ah hwa in kinrara..
His location.....Perak....:smokin:
biao
348
24
perak / ipoh
you means the mid-box?
actually is all gear can run, just only the 1st, 2nd and 3rd gear will have sound came out. sound like metal grinding.
and last night have happen on 1st gear look like slip when waiting traffic light cannot move.
biao
348
24
perak / ipoh
Then come up to see Ah Wah.......lol:driver:
ya later will call him.
i just scare later is gearbox problem then need to change, suddenly dont know go where get it. because i need on the same day get the car. that's why i need confirm the problem then get the solution. now i have search the gearbox halfcut and recond.
4gbanger
1,958
386
1,683
Johor/ShahAlam
better get the car for check first. sometimes not every error is a big issue.. sometime only atf not enuf so the gear changes slow and snapping.. better send your car there in the morning, get some fren to follow u, and if really need to get a set of gearbox u can drive to buy.. there are few halfcut shop to go for.. i counted its 4 shops around selangor. which 3 in puchong and 1 in subang for airtrek turbo parts.
biao
348
24
perak / ipoh
i already call ah wah. he confirm is the gearbox spoil. he say 1 of the gear spoil and make the sound grinding. so he suggest me change gearbox because cheaper and fast. and he say wait he find the gearbox just let me know.
biao
348
24
perak / ipoh
i need some idea from you all.
option 1: buy a halfcut gearbox to change it
option 2: overhaul the gearbox
option 3: buy a rebuilt gearbox to change
which is better ?
which is better ?
3 is like 2, some will want your old gb in exchange.
For me if keeping the car, either 2 or 3, since overhaul means change new parts etc...
halfcut gb, don't know the history of it.....:smokin:
biao
348
24
perak / ipoh
yup, the 3 is need my old gb in exchange. if 2 cost very high, some quote me 2k+
Might as well trade in if can get cheaper. Keeping old gb also no point, unless can keep for spare parts......:smokin:
from down pipe i use back the original evo2 and can i use the putra mid and the rear muffler? Must stand until puspakom inspection.:p Will this spoile my 4G63 engine? Can sifu out there share the time period using between convertion done and puspakom inspection.
Thank you.
