Help on Perdana V6 Twin Turbo
AJAY6666
Mar 12, 2017
16
Hai guys i need help and suggestion on my Perdana v6 twin Turbo 6a12tt regarding changing timing belt and engine mounting.I went two workshop so far,they're said use the same Perdana v6 timing belt,is that true? Regarding engine mounting Which workshop is trusted around klang valley._also im gonna change belting,water pump,spark plug,down parts lower arm,upper arm etc.Thanks in advance guys.
marsha1l_v6
666
130
543
Hi Ajay..TT timing belt and mounting using same with it's na counterpart..Do get dayco belt as mention by bro danz. Mounting I would recommend full rubber for front and rear since using turbo.
As for lower arm etc, what's ur budget? There are few types out there with different reliability. Eg: cheap one can last 1 year +- before wear out.
I have my usual go to mechanic, I've been with him since my v6 is NA auto --> NA manual --> evo3. All done by him transplant and Maintenance at kesas/kinrara
AJAY6666
16
Hai bro thanks for u advice._do u know where to get the rubber mounting ? For lower arm budget around rm500 only.Btw im from puchong
AJAY6666
16
Also want ask regarding turbo,when engine cold its more power,after like 30min drive,feel less respond.Acceleration abit slow..Wondering why.
marsha1l_v6
666
130
543
rubber mounting i got it from my mechanic, i was looking for pu mounting, but he recommend full rubber as i use my pevo as daily drive. Price about rm150 for front only including installation. Abit pricey for full rubber
iinm 5xx - 6xx you able to get full set front arm with a good set though. You can hunt for those part at any spare part shop.
As for you turbo,iirc during cold engine, not advisable to boost or push your engine as EO is not at optimum temp but if you have cold air/cold ambient temp especially in the morning, it does help for turbo charged engine. :driver:
Could be turbine heated up, charged air not cool enough as compared to earlier time when just started...
AJAY6666
16
Thanks for the Reply bro Marshal,today i changed the engine mounting..it's cost me RM275 4pcs..confirm not ori..due to my budget,i just changed it.upah pasang cost me rm220.not include gst.
i asked for the Timing Belt at spare part shop.RM420 Original Mitsubishi.as he said.i saw at Mudah got one guy selling Dayco brand for rm230 only.imitation or what??
turbine heated up? :o any solution for that bro? shud i service my turbo?
After driving the exhaust gas will heat the turbine up, that is why we need the intercooler.
Initial drive time all is cool, 30 minutes later sure to be hot...lol
Probably need to cool intercooler more, maybe add water spray....:driver:
marsha1l_v6
666
130
543
iinm there is no ori/ not ori for engine mounting, i guess you bought the semi rubber one. v6 abit expensive.
abit pricey for that timing belt. last time i bought around rm4xx timing belt + water pump. Bought myself gates as it comes with warranty.Have you done your top overhaul?:hmmmm:
AJAY6666
16
nop..i didn't do top overhaul.because there is no white smoke.engine still good running.only can hear tappet sound.so i will go for the timing belt which cost rm400+.together with waterpump.any other thing i have to do? because i just bought this car from used car dealer.
Hi, i am driving satria with first gen mivec. Unfortunately my alternator worn out recently. Is there any alternative for replacement since the same mivec alternator is really hard to find. Thank you.
